Tibber: energy consumption not updated real time
I am a customer of tibber and user of the Tibber Pulse to track my energy consumption in real time here in Germany.
I added Tibber via the official integration but energy consumption in only updated with a lag of several hours, sometimes half a day in energy dashboard. If I reload the integration, up to date data is presented, so it seems to be available.
Is there any way of tweaking the (automatic?) update of the energy entity?
@Danielhiversen I hope it is ok to ping you here. I was digging around a bit with the developer portal and found out that real time consumption doesn’t seem to be enabled, although I am using the Pulse:
  "data": {
    "viewer": {
      "home": {
        "id": "myhomeid",
        "features": {
          "realTimeConsumptionEnabled": false
If you have a Pulse and the api responds with “realTimeConsumptionEnabled”: false, something is wrong on the Tibber side. You should report it to Tibber.
Thanks for your answer, I’ll send them a mail so they can fix it.
Might this also affect my initial issue with the update frequency of the energy entity? Any idea?
Yes, since Home Assistant do not know you have a real time meter, the consumption is not fetched that often.
The guys at Tibber seemed to have enabled my real time consumption API access. Now not only my energy dashboard is always up to date, but I also received 13 new sensors including my real time consumption.
So thanks a lot Daniel for your help!
Hey Daniel,
I have almost the same problem.
My meter is an ITRON ACE3000 (listed on Tibbers white list). It only provides the actual meter-value (no power consumption etc.) every 10-12 seconds.
I can’t see any data in the app and also not via the API explorer.
  viewer {
    homes {
      id
      features {
returns
  "data": {
    "viewer": {
      "homes": [
          "id": "XXXXXX",
          "features": {
If I am right I should get “true” as soon as a Pulse is installed?!
Is there any difference between a meter providing live-data and a meter only providing the total meter-value (kWh)?
The support told me I can try this via “lastMeterConsumption” - but this only works with “realTimeConsumptionEnabled”: true - am I right???
And they told me that they can not change the status from “false” to “true” manually.
Thanks for your help!
