Ardutis
(Arvydas)
May 8, 2026, 8:42pm
1
Home Assistant Core 2026.4.4 seems to have broken my Tibber integration and possibly corrupted the integration/frontend state after rollback attempts.
Setup:
What happened:
After updating to 2026.4.4, Tibber Pulse realtime entities started freezing after a few minutes.
Entity values stop updating completely.
last_updated no longer changes.
Restarting Home Assistant temporarily restores realtime updates, but only for a short time.
Tibber official app continues working perfectly, so Pulse hardware and Tibber cloud connection appear OK.
Things already tested:
Restart Home Assistant
Reload integration
Disable/enable Tibber integration
Delete and re-add Tibber integration
Rollback attempt to 2026.4.3
Re-authentication
Reserved static IP for Pulse
Verified WiFi connectivity
Current state:
Tibber OAuth flow completes successfully ("Done!")
However, the Tibber integration is not actually added afterward
Sometimes the frontend becomes unstable:
Add Integration button becomes unresponsive
"Unable to connect to Home Assistant"
Missing icons / broken UI behavior
Logs mostly show missing old entities after Tibber removal, but no clear Tibber auth error
Important:
Everything worked correctly before updating
Issue started immediately after update
Rollback did not fully restore previous behavior
Question:
Has anyone seen similar Tibber/Pulse behavior after 2026.4.4 or rollback attempts?
Could this be a corrupted config-entry/frontend state issue or a regression in Tibber realtime handling?
Kurha78
(Kurha78)
May 9, 2026, 8:18am
2
Hi! I have the exact same problem.
Try updating to 2026.5.1, there are some Tibber-related fixes in that release.
Ardutis
(Arvydas)
May 9, 2026, 11:11am
4
Thanks. Maybe it's worth waiting for even newer ones?
buur85
(Buur85)
May 9, 2026, 1:40pm
5
Uppgrade seemed to have solved it for me
Solved it for me as well!
Ardutis
(Arvydas)
May 10, 2026, 12:02pm
8
Update:
I upgraded to Home Assistant Core 2026.5.1.
The realtime freeze issue may be improved, but now I still cannot add the Tibber integration properly.
OAuth completes successfully and I get:
"Done! Your account is now linked"
However:
no Tibber integration appears afterward
no Tibber entities are created
Application Credentials is empty
logs show no Tibber authentication errors
I only see unrelated warnings/errors (for example Tuya unique ID warnings and missing old entities after previous Tibber removal attempts).
Could previous rollback/delete/re-add attempts have corrupted the config entry or integration flow somehow?
Ardutis
(Arvydas)
May 10, 2026, 12:29pm
9
Update:
Adding Tibber from the Home Assistant mobile app still failed for me after OAuth “Done”.
However, adding the integration from a desktop browser completed successfully and restored all devices/entities, including Tibber Pulse realtime data.
System seems stable now, still testing.
Ardutis
(Arvydas)
May 13, 2026, 7:22am
10
After a few days of testing, everything seems to be ok.
gumi82
(Gumi82)
May 15, 2026, 7:21pm
11
Yesterday I conect my tibber pulse localy via Mosquitto broker MQTT and I have same problem with frozen after few minut, I have HA 2026.5.1. I have bridge so also I have data in tibber app and if I open app then data comes back to HA also. Someone have some Idea?
buur85
(Buur85)
May 21, 2026, 9:27am
12
Latest core update killed my Tibber again.
