Hello everyone,
after I got some sensors working via configuration.yaml I soon want to tidy up this file and split it to “sub-yamls”.
I want following yaml files to include in the configuration.yaml:
config/sensors/devices.yaml
config/sensors/temperature.yaml
In configuration.yaml I include those two files via
template: !include_dir_merge_named sensors
I tried with trailing / and without.
# temperature.yaml
- sensor:
- name: "Konstant Schwellwert Temperaturdifferenz"
unique_id: konstant_schwellwert_temperaturdifferenz
state: >
25
unit_of_measurement: "°C"
device_class: temperature
- sensor:
- name: "Konstant Minimum Aussen"
unique_id: konstant_minimum_aussen
state: >
10
- binary_sensor:
- unique_id: temperaturdifferenz_schlafzimmer_aussen
name : Temperaturdifferenz Schlafzimmer - aussen
state : >
{% set temperatur_schlafzimmer = states('sensor.temperatur_schlafzimmer') | float(100) %}
{% set temperatur_aussen = states('sensor.temperatur_aussen') | float(-100) %}
{% set konstant_minimum_aussen = states('sensor.konstant_minimum_aussen') | float(0) %}
{% set diff = temperatur_schlafzimmer - temperatur_aussen %}
{% if diff < konstant_minimum_aussen %}
True
{% else %}
False
{% endif %}
#devices.yaml
- sensor:
- name: Starte Geschirrspueler
unique_id: sensor.starte_geschirrspueler
state: >
{% if states("sensor.siemens_geschirrspueler_remainingprogramtime") not in ["unknown", "unavailable", "", None] %}
{% set sensor = 'sensor.epex_spot_data_net_price' %}
{% set date1 = as_timestamp(now()) %}
{#{ date1 | timestamp_custom('%D-%H:%M', local=True) }#}
{% set date2 = as_timestamp(states('sensor.siemens_geschirrspueler_remainingprogramtime')) %}
{#{ date2 | timestamp_custom('%D-%H:%M', local=True) }#}
{% set difference = date2 - date1 %}
{% set hours = (difference / 3600) | round(2) %}
{% from 'cheapest_energy_hours.jinja' import cheapest_energy_hours %}
{{ cheapest_energy_hours(sensor=sensor, hours=hours, start='06:00', end='22:00', include_tomorrow=false) }}
{% endif %}
availability: >
is_state('switch.siemens_geschirrspueler_powerstate', 'on')
and is_state('binary_sensor.siemens_geschirrspueler_remotecontrolstartallowed', 'on')
and is_state('binary_sensor.siemens_geschirrspueler_doorstate', 'off')
The sensors in the two extra files will not load > developer tools say unavailable > not integrated any more.
I have Studio Code Server installed, wich is very helpful, but it shows a platform error when editing the two extra yamls.
I tried around a day, but cant find what’s wrong. Pls help.
