Tidying up Automations
So, I have the following 9 Automations and I’m looking for suggestions on how I could tidy them up the best way. They all run with similar parameters and I believe they currently putting a reasonable load on the system.
Would i be best using Scenes / Scripts? And how would they look?
# Fibaro Change Channel
- id: fibaro_kids
  alias: Variable Channel Kids
  - entity_id: sensor.ha_change_channel
    platform: state
    to: '1'
  - data:
      command:
        - 2
        - 2
      device: "20292110"
      entity_id: remote.living_room
    service: remote.send_command
- id: fibaro_mate
  alias: Variable Channel Mate
    platform: state
    to: '2'
  - data:
      command:
        - 6
        - 3
      device: "20292110"
- id: fibaro_life
  alias: Variable Channel Life
    platform: state
    to: '3'
  - data:
      command:
        - 5
        - 4
      device: "20292110"
- id: fibaro_nine
  alias: Variable Channel Nine
    platform: state
    to: '4'
  - data:
      command:
        - 5
        - 0
      device: "20292110"
- id: fibaro_go
  alias: Variable Channel Go
    platform: state
    to: '5'
  - data:
      command:
        - 5
        - 3
      device: "20292110"
- id: fibaro_seven
  alias: Variable Channel Seven
    platform: state
    to: '6'
  - data:
      command:
        - 6
        - 0
      device: "20292110"
- id: fibaro_me
  alias: Variable Channel Me
    platform: state
    to: '7'
  - data:
      command:
        - 2
        - 3
      device: "20292110"
- id: fibaro_abc
  alias: Variable Channel ABC
    platform: state
    to: '8'
  - data:
      command:
        - 2
        - 0
      device: "20292110"
- id: fibaro_sbs
  alias: Variable Channel SBS
    platform: state
    to: '9'
  - data:
      command:
        - 3
        - 0
      device: "20292110"
Why do you think that?
They sit there doing nothing using no resources until triggered. It does not look like they would be triggered very often either.
When they are triggered they don’t do massive recursive operations either. Just one straight forward service call.
Even if you surf tv channels all night your cpu would barely notice.
You could do something like this:
- id: fibaro_change_channel
  alias: Fibaro Change Channel
    platform: state
  - data_template:
      command:
        - "{{ [2, 6, 5, 5, 5, 6, 2, 2, 3][trigger.to_state.state|int - 1] }}"
        - "{{ [2, 3, 4, 0, 3, 0, 3, 0, 0][trigger.to_state.state|int - 1] }}"
      device: "20292110"
EDIT: It’s possible, however, that that won’t work, if the remote.send_command service doesn’t properly deal with strings in its command parameter. I’ve seen this before with other, similar services. In that case, the action could very easily be done in a python_script that is called by the automation.
That’s pretty nifty Phil.
