Tile card should accept "color" when using with buttons to call scripts (which never have "on" state, so never color))
As the title suggest it would be nice if the tile card supported color when using call-script actions. Since otherwise the icon always stays grey, because a script will only run for 1 second. And by default, the color is based on state, domain, and device_class. While I just want to give the icon a color.
don’t forget to vote for your own suggestion!
There are so many (great) suggestions here. I afraid they end up knowhere in the end :frowning:
A change of system maybe?
This also is the case for the Mushroom Entity Card, so that isn’t a proper workaround.
You could use the Mushroom Template Card as a workaround, but the available colors differ a little from the Tile card.
