Got it
Updated the .yaml file and alls good.
Example configuration.yaml entry
- platform: time_date
display_options:- ‘time’
- ‘date’
- ‘date_time’
- ‘date_time_utc’
- ‘date_time_iso’
- ‘time_date’
- ‘time_utc’
- ‘beat’
Got it
Is it possible to enable/disable an automation tile?
I want to keep it in the UI but without being able to activate it sometime based on different conditions.
If you really want to use images as background for the tile you can simply resize them and if I’m not mistaken you can play with bgSize
: https://www.w3schools.com/cssref/css3_pr_background-size.asp
I think there was a bug in previous versions which was fixed: https://github.com/resoai/TileBoard/pull/551
Hey, quick question. Seems the gauge sensor rounds the central value with a decimal even tho. the fractionSize setting is set to 0 and the value in the top corner shows watts. Can this behavior be disabled via settings? I would prefer it to show watts and not kilowatts if possible without code modification.
This is not rounding, it’s the thousands separator. Maybe in your country, the comma is not used as a thousand separator and that’s why it confuses you. Which is fair but currently TileBoard runs in US locale only.
could I just bump this a I am really struggling to find the answer?
Maybe something like this in custom.css
.item.-th-history {
background-color: rgb(130, 156, 108);
You can define a custom action
for the automation tile:
action: function(item, entity) {
if (false/* can not run */) {
return
this.$scope.triggerAutomation(item, entity)
Thanks, I’ll look into it
Ideally, I would have like the tile to be “disabled”, kind of like the arrows on the cover tile are handled
But thanks for the reply, that’s a great alternative
Thanks, for the reply. My original post was unclear I meant the history tile line not the background.
I’m also looking for a way to do this. Did you found a solution for this?
You can define the timeout for closing popup like so: this.$scope.popupTimeout = 10;
and also close popup by calling this.$scope.closePopup();
dear @resoai and @rchl , i need to make a gauge that have dynamic thresholds but i can manage to get the sensor state in to thresholds key.
position: [5.35, 0],
width: 1.9,
height: 2.2,
type: TYPES.GAUGE,
settings: {
type: "arch",
min: 0,
max: 45,
cap: "butt",
thick: 3,
append: "°C",
labelOnly: false,
thresholds: {
0: {
color: "green"
[xxxxx+5]: {
color: "orange"
40: {
color: "red"
fractionSize: 1,
What i need is instead of xxxxx to get the sensor state.
this.parseFieldValue("&sensor.wanted_temp.state")
will not give the sensor value.
i can replace xxxx with a function, but again, i dont know how to get the sensor value in that function and where to put that function.
Please give me some hints to make this work.
Not getting into details, you probably need to convert this.parseFieldValue("&sensor.wanted_temp.state")
to integer.
i dont know how or where to convert it,
if i put :
thresholds: {
0: {
color: "green"
[Number(this.parseFieldValue("&sensor.wanted_temp.state"))-5]: {
color: "orange"
40: {
color: "red"
i get error:
Uncaught TypeError: undefined is not a function
please please get into few details…
The thresholds
needs to be a function.
Also, due to how AngularJS works, the computed return value needs to be cached or it will go into an infinite loop.
Something like this maybe (not tried so you might need tweak a bit):
settings: {
thresholds: function(item, entity) {
const wantedTemp = this.states['sensor.wanted_temp']
if (!item._cached_thresholds) {
item._cached_thresholds = {
0: { color: 'green' },
[wantedTemp + 5]: { color: 'orange' },
40: { color: 'red' }
return item._cached_thresholds
Thank you very much @rchl, that is the solution. I did not know how to put the array in to cache so that it will not be readed by angluar as new array every time. Thank you again
once more, i need youre knowledge @rchl, . the gauge will not chage the colors if the reference value, wanted_temp
, is changed.
how cand i use detectChanges() of angular in a tile as action or any function that will reset the chacked function?
