Track attendance at your workplace by recording arrivals and departures in one or more Google Sheets. ![]()
Like this blueprint? Consider hitting the
button below ![]()
Need help?
See our FAQ: Click Here
The Automation Process:
- Activation with RFID Tag:
- Specify your employee’s name. This must match the name assigned to the RFID tag and the input_text entity created previously…
- You can customize the column names that will be displayed in the Google Sheet.
- Once you have selected Google Sheet and entered the sheet name, the automation is ready for:
- Identify the RFID Tag: Bring the tag close to the reading device so that it can also be read by a Smartphone (which has NFC)
- Transcribing to Google Sheet: will write the Date, Time, Tag Name if it has entered, with the exit it will also write the Duration.
button below ![]()
CHANGELOG
- Version: 1.0 - 01 Dec-25 - Initial release
MY OTHER BLUEPRINTS
Notifiche & Annunci con Telegram e WhatsApp
Timbratura Ingresso/Uscita NFC in Google Sheet
button below ![]()
