Time Counter Logic Homematic/ Raspberrymatic
Hello community,
I am facing a problem with Homematic/ Raspberrymatic that is difficult for me to solve.
The task is as follows:
There are several valves from which I have extracted the valve opening and added them via script.
The result is the system variable “Ventilöffnung_All”.
I would now like to create a program that contains the following logic:
If “Valveopening_All” >= 250, then
Start Time Counter (1800 seconds).
If the value of “Ventilöffnung_All” < 250 within this time, the Time Counter is reset and as soon as “Ventilöffnung_All” >= 250 again, it starts again from the beginning.
If the value of “Valve_opening_all” is still >= 250 after 1800 seconds, then device XYZ should be triggered to on.
I’ve already tried a few things and I can’t get any of the solutions to work properly because I can’t get a proper time counter to work…
Maybe you can help me or maybe you know a template code which I can change.
Many thanks in advance
Just create a Automation
the Trigger would be
Valveopening_All above 250
  - trigger: numeric_state
    entity_id:
    - sensor.Valveopening_All
    above: 249
Create a Help timer “Valveopening_All”
for 1800 well it only know hours:min:sec 03:00:00
  actions:
  - data:
      duration: 03:00:00
      entity_id: timer.Valveopening_All
    action: timer.start
so that be on automation
now the other one
    entity_id:
    below: 249
add a condition check if timer running
condition: state
state: active
in the action part we can cancel a timer
  actions:
  - target:
    data: {}
    action: timer.cancel
now if the timer is
trigger: state
entity_id:
  - timer.Valveopening_All
to: idle
check the condition
condition: numeric_state
entity_id: sensor.Valveopening_All
above: 249
this should point down the right track well a track
there more than one way to skin this cat.
i like written in YAML
but you could create in the GUI
dont try and do all in one automation
use each automation to solve 1 problem
once you get your haed around you mite beable to in 1 automation.
let us know how you get on.
Hello Myle,
in Home Assistant this would be absolutely no problem for me, but I want/need to programme this in the Raspberrymatic environment, that’s where the problem lies :wink:
