I’m curious what causes the time in Hassio to be shown as am/pm, but any sensors added by me display 24-hour display. Do you guys have the same experience?
@Dennis87 I don’t see a bug here. History or Logger does not have a time_format:
The bottom graph is most likely based on your system time. Try changing your system time to 24 hr format. If that doesn’t work, then this could be a good feature request.
It isn’t wrong though. I use my history book every week to verify my time in/out at work. It has been 12 hr am/pm format since 0.34. I know this because I have to convert my time to 24 hr when inputting my time sheet. You’re welcome to argue all you want, but nothing has changed…
Very strange the time was shown in 24 hour format before for about 1 month ago? I I have not changed anything on the install as I have just upgraded. Maybe a hass.io system time issue. It did happen after one of the upgrades but I don’t remember exactly when. Was around update 0.60+. My time_date sensors show the time in 24h format.
As I said before, I am pretty sure it pulls the time from the device that the HA is on. If you are using a database on a different device, it depends on that device. This is using data from a SQL look up (history or record component), and that is most likely coming up with the dates and times.
Found the issue. My browser setting was US English Did change to UK English and show correct now. So this must be a change done so it show time format based on browser locale.
