I have an install on a Raspberry PI 4 of hass.io 64 bit from here: https://www.home-assistant.io/hassio/installation/
When booting, the time will only update if I am physically connected to the network via cable. Starting with wifi only does not update the time.
This causes an issue on power cycle of the pi and supervisor starting all the containers. A soft reboot results in everything starting as it should.
Is this an issue with hassos or something that has existed and will not be fixed?
I am saying it is a time issue because of the response I get here: https://github.com/home-assistant/supervisor/issues/1649
