Now this is the weirdest thing I have ever seen…can someone explain it…
I upload the code to a Huzzah (ESP12) with a max7219 8x8 LED matrix. and it compiles and loads. It works fine, it starts with 01:00 on the display but after a few seconds the correct time is displayed, that the logs also show…
Now I go away, and the PC that contains the website with which I acces the HA node (HP Thinclient) goes in standby…a short while later the displays shows 01:00 again and after it reaches 01:15, it goes back to 01:00…
When I wake up the PC and restart logging the right time apears again, when I do not restart logging it keeps displaying 01:xx,…So it is directly related to the logs
Can anyone explain this?
friendly_name: LEDpanel
esp8266:
board: huzzah
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "9sx6gK0Pj5Y="
ota:
- platform: esphome
password: "5fe0592db5996ddab6018abe8fdb4a5f"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Ledpanel Fallback Hotspot"
password: ""
font:
- file: "fonts/adf-5x8.ttf"
spi:
clk_pin: GPIO14
mosi_pin: GPIO13
time:
- platform: homeassistant
timezone: Europe/Amsterdam
text_sensor:
update_interval: 10s
lambda: return id(HA_time).now().strftime("%H:%M");
display:
- platform: max7219digit
cs_pin: GPIO15
num_chips: 4
intensity: 7
scroll_mode: STOP
lambda:
it.print(0, 0, id(digit_font), id(current_time).state.c_str());
captive_portal:
type or paste code here
