I am trying to have my garden drip system turn on every hour on the hour between Sunrise and Sunset. I have tried many variations of the following YAML, all created via the gui but none seem to work. I am triggering a zone on my Rachio sprinkler system which works manually or via other triggering mechanisms. Any help would be appreciated.
(Device ID removed but it is correct in the real code)
alias: Keep Garden Wet
description: Run the Garden Drip System
- platform: sun
event: sunrise
offset: 0
- platform: time_pattern
minutes: "0"
condition:
- condition: sun
after: sunrise
before: sunset
- type: turn_on
device_id: ********
entity_id: switch.garden
domain: switch
mode: single
Thank you very much. After looking at the link you sent, I was able to follow the trace and see what is causing the final issue. it appears that the “after sunrise” condition is not showing sunrise in my location, but Amsterdam.
I was able to get my location changed and now the time of sunrise and sunset is correct.
