Time Pattern Automation not triggering
Hi, I’m trying to get an automation triggering every 5 mins. I can trigger it manually and it runs. However the Time pattern does not trigger it.
Can anyone help me and see what it might be?
alias: wled text
description: ""
  - platform: time_pattern
    minutes: "5"
condition: []
  - device_id: aeda4f433ea610a7b873653f5f29452e
    domain: select
    entity_id: select.led_matrix_preset
    type: select_option
    option: Scrolling Text
  - data:
      payload: >-
        {"seg":[{"id":0, "n":"It is {% set forecast = state_attr('weather.home',
        'forecast')[0] %}{{forecast.temperature}}c outside"}]}
      topic: wled/081664/api
    service: mqtt.publish
  - delay:
      hours: 0
      minutes: 0
      seconds: 14
      milliseconds: 0
    domain: select
    type: select_option
    option: Black Hole
mode: single
Check the documentation here: https://www.home-assistant.io/docs/automation/trigger/#time-pattern-trigger
Change “5” to “/5” and it will evaluate every 5 minutes.
Thanks so much, ill give that a try
That fixed it :slight_smile: It’s always the simple things hahah
