Time slider variant
I thought I’d share a variant of a time slider to set a HH:MM value. It looks like this:
time_slider_past_midnight
This is the config:
input_number:
  nattvak:
    icon: mdi:cursor-pointer
    initial: 25
    min: 23
    max: 28
    step: 0.5
  platform: template
  sensors:
    nattvakstid:
      friendly_name: 'Tid att kolla'
      value_template: >
        {%- if states("input_number.nattvak") |float < 24 %}
          {% set nighthour = states("input_number.nattvak") | int %}
        {% else %}
          {% set nighthour = (states("input_number.nattvak") | float - 24) | int %}
        {% endif -%}
        {% set nightminute = ((states("input_number.nattvak") | float - states("input_number.nattvak") | int) * 60) | int %}
        {{ "%0.02d:%0.02d" | format(nighthour, nightminute) }}
It is using only whole and half hours, but could easily be modified to use whatever fractions of an hour that you like. The nice thing about this slider is that it goes from before to beyond midnight using a decimal number between e.g. 21 to 27 and translates it into a correct time string from ‘21:00’ to ‘03:00’.
I find it useful. Hope somebody else does too.
