swiim
March 17, 2023, 7:14pm
1
I’m a total newb making my first automation and have no experience with YAML.
“sensor.bedste_3_timer_i_dag” contains only the hour and time trigger expect at least HH:MM, what’s the normal/easiest way to add the “:00”
alias: Opvaskemaskine start ved billig strøm
description: ""
- platform: time
at: sensor.bedste_3_timer_i_dag
condition:
- condition: and
conditions:
- type: is_on
condition: device
device_id: b12c69c35cee6f3d260ca600a358ae0e
entity_id: >-
binary_sensor.gaggenau_df270160f_68a40e0c737b_bsh_common_status_remotecontrolstartallowed
domain: binary_sensor
- type: is_not_open
condition: device
entity_id: >-
binary_sensor.gaggenau_df270160f_68a40e0c737b_bsh_common_status_doorstate
- condition: device
domain: select
entity_id: select.gaggenau_df270160f_68a40e0c737b_programs
type: selected_option
option: Dishcare.Dishwasher.Program.Eco50
- device_id: b12c69c35cee6f3d260ca600a358ae0e
domain: button
entity_id: button.gaggenau_df270160f_68a40e0c737b_start_pause
type: press
mode: single
As long as your sensor has the timestamp
device class, you should not need to do anything. The “HH:MM” format is accepted by Time triggers .
FWIW, there’s no reason to use an “And” condition the way you have in your condition block.
swiim
March 17, 2023, 8:03pm
5
It is not a timestamp device class. It’s an int that only contains the hour - etc. 3 or 21.
Sorry, I mis-read the original post… AFAIK, Time triggers do not accept templating, so you just need to use a template trigger.
description: ""
value_template: >
{% set x = states('sensor.bedste_3_timer_i_dag') %}
{{ now() >= today_at(x~":00")}}
condition:
- type: is_on
condition: device
entity_id: binary_sensor.gaggenau_df270160f_68a40e0c737b_bsh_common_status_remotecontrolstartallowed
- type: is_not_open
condition: device
entity_id: binary_sensor.gaggenau_df270160f_68a40e0c737b_bsh_common_status_doorstate
- condition: device
domain: select
domain: button
type: press
mode: single
swiim
March 17, 2023, 8:18pm
7
Thanks ill give it a try and know if it works after 2 am
And thanks for also cleaning up the “condition: and”
