Timeout sending notification -> Needs app to be wiped to work again
Hi, every few days, my notifications are failing with the below error:
Log details
Logger: homeassistant.components.mobile_app.notify
Source: components/mobile_app/notify.py:202
integration: Mobile App ([documentation](https://www.home-assistant.io/integrations/mobile_app), [issues](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+mobile_app%22))
First occurred: 9:11:16 AM (4 occurrences)
Last logged: 9:36:59 AM
Timeout sending notification to https://mobile-apps.home-assistant.io/api/sendPush/android/v1
Action used
action: notify.mobile_app_sm_g781v
metadata: {}
  message: "Test 123"
Integration used
This service is provided with the Mobile App integration (link)
Phone information
I have a samsung galaxy S20 FE running One UI 5.1 and Android 13. My home assistant app says ‘Core 2025.3.4’ and ‘Frontend 20250306.0’
I think its not a problem with my action, because it used to work. Also, when I see this error, if I use the ‘clear data’ function on my phone, it works again. Then fails again after a couple days…
Any idea how to begin debugging this? Or alternatively, another service to use? Its concerning to not get notifications especially when they’re tied to critical automations (i.e. water leaks, alarm triggers, etc)
There is an open issue on Github, you may want to add your information there.
