Lee26
(Lee26)
November 24, 2024, 10:24pm
1
Hi All,
I’m progressing well with HA, but need to start to work with timer helpers instead of delays in my automations.
Unfortunately, when I create a new timer helper it doesn’t get added to the helper lists.
I have checked config.yaml and default_config: is there.
How do I get the helper timer available?
Lee
Lee26
(Lee26)
November 25, 2024, 8:13pm
3
Thanks Nick for the response.
There is no entity created so can’t add to the dashboard
Recreated the same and different timer helpers but none show in the helper list for are accessible entities
I’ve not tried refreshing cache (school boy error maybe) so will get on to that when I get home
Reset HA a few times no difference
Best Wishes
Lee
Nick4
(Nick)
November 25, 2024, 8:36pm
4
I assumed that creating the same helper would give a notification/error but it just adds an index.
Go to Settings → Devices & services → Helpers to check there.
Lee26
(Lee26)
November 26, 2024, 6:19pm
5
Thanks Nick your advice was spot on, just refreshed Cache and surprise surprise they are showing.
Best Wishes
Lee
Nick4
(Nick)
November 26, 2024, 9:59pm
6
Good for you that it works now Lee!
Please mark the post with the answer that helped you as the solution so anyone who’s searching for this can benefit from it.
You do that by selecting the three dots under the post:
Then select the check box:
Also, by doing so this prevents that someone else steps in for trying to help.
