Not big deal, but I got very much confused recently, trying to troubleshoot one of my automations. Seems Developer Tools are not properly displaying timer entities properties for active timers in table view. Is it me only?
Defo something not right.
I just set up a test timer of 5 mins, when I start the timer its stars counting down from 6 min & 50 sec and not 5 mins as set, however if I pause it it then displays the correct time left until I restart (un-pause) it and then its back to displaying 1 min 50 sec more again and continues to count down with this incorrect time.
In Dev tools the remaining time does not update at all when the timer is running, however it does update once each and every time I pause it, if the timer is running the remaining time is stuck on either the start duration (which does correctly show 5 mins and note 6 min 50 sec) or the time remaining when I last paused it.
EDIT: Just discovered something I had not thought about, the reason my 5 min timer starts with 6 min 50 sec is because that the time difference between the HA instance machine and the remote PC I am using to access it
