This is driving me nuts. I can’t seem to figure out how to get my timestamp (which I believe is sent to me as a UNIX timestamp, I assume in UTC) into HA as a timestamp object.
If I make it a device-class of timestamp, it just says ‘unknown’. If I take that out, I get a number which online UNIX time converters seem to do properly.
Example state (from 2:09 PM Eastern/US on Dec 19, 2022): 1671477004429
Code:
mqtt:
# Ecoflow MQTT Sensors
# MQTT Topic Update metadata
- name: "Ecoflow Params Last Updated"
#icon: "mdi:clock"
#device_class: timestamp
force_update: true
state_topic: "bridge-ecoflow//app/device/property/DAABZ5ZE8020852"
value_template: >-
{% set value = value_json['params']['latestTimeStamp'] %}
{% if not value is defined %}
{{ this.state }}
{% else %}
{{ value | int("invalid") }}
{% endif %}
I see lots of threads people going from the ISO format to seconds to do math, but nobody going the other way?
So how do I get this into HA with a proper timestamp so I can compare stuff like whether it’s newer/older than other stuff like I’m accustomed to with other sensor attributes?
