Since there is not alot of info regarding the use of raspbee on tinkerboard i tought i should share my experience.
To get Raspbee working on tinkerboard you do the same as you would on a raspberry pi3.
But the usb path is different to use GPIO.
on the tinkerboard you would need to replace usb_path: /dev/ttyAMA0 with usb_path: /dev/ttyS1.
and allso i did not need to edit the config.txt file to get it to work.
Hope this helps
