I updated this morning from .35.3 to .37 and found that my Squeeze component no longer worked.
Be aware that the recent (excellent) changes to the component now require that you point the “port” field at the Web/JSON port, not the CLI port.
Hmm, isn’t it the opposite?
That since .37 it is using JSON and not CLI?
Correct. Sorry - updated post.
If my squeezebox is setup by Discovery, is there anything I need to change or is the updated port automatic?
EDIT, never mind, I see that it’s automatic.
