Hello everyone, the attached one is a tuya compatible thermal magnet. I wanted to buy a thermal magnet similar to this, but natively supported by HA. Advice ?
That device will work with tuya local, I have one that has been running with tuya local for a long time.
No idea about a natively supported one though.
Hello and thank you, about local tuya I thought to install it, but if I perform the installation from hacs, the current one and its devices what do they do? Should I reconfigure everything?
If you already have devices set up in tuya integration then adding tuya local will create new devices os any automations you have will need the new devices adding / changing.
Its been a long time since I changed over but I think that is what happened, get it working with tuya local, then delete the tuya integration.
