Title: collectd + MQTT sensor = post-processing weirdness, need help
OK, so I’m using an instance of collectd to pull together some system monitoring stats on my server. It’s running fine, and it’s forwarding data to Home Assistant via MQTT sensors as desired. Each MQTT message from collectd includes a timestamp followed by one or more measurements, with the fields separated by colons.
So to provide a couple of examples, free memory messages look like this:
1572919890.285:11632119808
Each memory-related message has a timestamp followed by the measurement in bytes. That’s a lot of bytes and hard to visually parse.
System Load messages look like this:
1572919890.267:0.0675:0.0728125:0.041875
Here each timestamp is associated with three measurements - 1m, 5m, 15m as is normal with the unix system load average measurement.
It’s easy to pull these measurements into HA with MQTT sensors - I just discard the timestamps and pull the data like this:
value_template: “{{ value.split(’:’)[1] }}” for the memory sensors, and
value_template: “{{ value.split(’:’)[1 or 2 or 3] }}” for each of the load sensors
Unfortunately, any further post-processing in the sensor templates fails - for the memory sensors and the 15m load sensor ONLY. The 1m and 5m load sensors seem to work fine. I suspect there’s something going on with the last split field from each MQTT message that I’m not able to see.
For the load sensors, I want to round the measurements to three digits. “{{ value.split(’:’)[ x ] | round(3) }}” works fine for the 1m and 5m measurements, but the 15m measurement doesn’t ever get truncated.
Some examples:
  - platform: mqtt
    name: Collectd Test Load 0
    state_topic: "collectd/192.168.17.10/load/load-relative"
    unit_of_measurement: '%'
    value_template: "{{ value }}"
^^^ This provides “1572919890.267:0.0675:0.0728125:0.041875” as expected - time stamp + 3 measurements
  - platform: mqtt
    name: Collectd Test Load 1
    value_template: "{{ value.split(':')[3] }}"
^^^ This provides “0.041875” as expected - the single measurement we want
  - platform: mqtt
    name: Collectd Test Load 2
    value_template: "{{ value.split(':')[3] | round(3) }}"
^^^ This provides “0.041875” - no rounding is occurring here (but for value.split(’:’)[2] | round(3), we would get “0.728” as expected
  - platform: mqtt
    name: Collectd Test Load 3
    value_template: "{{ (float(' ' ~ value.split(':')[3] ~ ' ') | round(3)) }}"
^^^ This provides “0.041875” - adding spaces to the split string doesn’t help
  - platform: mqtt
    name: Collectd Test Load 4
    value_template: "{{ (float(value.split(':')[3]) | round(3)) }}"
^^^ This provides “0.041875” - converting to float then rounding doesn’t work
For the memory sensors, I’d love to convert those raw bytes to gigabytes, but this fails: “{{ (value.split(’:’)[1] / 1073741824.0) | round(3) }}” - and so do various other attempts to rewrite them differently
  - platform: mqtt
    name: Collectd Test Memory 00
    state_topic: "collectd/192.168.17.10/memory/memory-used"
    unit_of_measurement: units
    value_template: >-
        value
^^^ This provides “1572919890.285:11632119808” as expected
- platform: mqtt
    name: Collectd Test Memory 01
    value_template: >-
        value.split(':')[1]
^^^ This provides “11632119808” as expected
  - platform: mqtt
    name: Collectd Test Memory 02
    value_template: >-
        (value.split(':')[1] | float)
^^^ This provides “0.0” as result - seemingly can’t convert this numeric value into a float?
  - platform: mqtt
    name: Collectd Test Memory 03
    value_template: >-
        ((value.split(':')[1] | float) / 1073741824.0)
  - platform: mqtt
    name: Collectd Test Memory 04
    value_template: >-
        ((" " ~ value.split(':')[1] ~ " ") | float)
^^^ This provides “0.0” as result - adding spaces around doesn’t help
  - platform: mqtt
    name: Collectd Test Memory 05
    value_template: >-
        (((" " ~ value.split(':')[1] ~ " ") | float) / 1073741824.0)
  - platform: mqtt
    name: Collectd Test Memory 06
    value_template: >-
        (float(" " ~ value.split(':')[1] ~ " ") / 1073741824.0)
^^^ This provides “unknown” as result - just moved the float() filter
  - platform: mqtt
    name: Collectd Test Memory 07
    value_template: >-
        ((string(value.split(':')[1]) | float) / 1073741824.0)
^^^ This provides “unknown” as result - tried to re-convert to string then float; doesn’t work
  - platform: mqtt
    name: Collectd Test Memory 08
    value_template: >-
        (((value ~ ': ').split(':')[1] | float) / 1073741824.0)
^^^ This provides “0.0” as result - added an extra delimiter and space at the end before splitting - doesn’t help
  - platform: mqtt
    name: Collectd Test Memory 09
    value_template: >-
        ((value.split(':')[-1] | float) / 1073741824.0)
^^^ This provides “0.0” as result - [-1] as index doesn’t help
  - platform: mqtt
    name: Collectd Test Memory 10
    value_template: >-
      {% set test_val = value.split(':')[-1] %}
        (test_val | float)
^^^ This provides “0.0” as result - setting a variable first then using the variable in the template doesn’t work
  - platform: mqtt
    name: Collectd Test Memory 11
    value_template: >-
        (test_val / 1073741824.0)
  - platform: mqtt
    name: Collectd Test Memory 12
    value_template: >-
        ((test_val / 1073741824.0) | round(3))
  - platform: mqtt
    name: Collectd Test Memory 13
    value_template: >-
        (string(test_val) | float)
I have tried just about everything I can think of.
All of these examples work 100% correctly in the template renderer in development tools! I can copy-paste MQTT messages from MQTT Explorer right into the template renderer (quoted literal strings instead of the value variable) and I’ll get correct results every single time. So it appears there’s something going on with the live data I can’t see.
And to add a further data point: I tried to use UPS Charge Percentage (also via collectd) in a mini-graph-card, but the MQTT sensor that feeds into it renders as “NaN” at all times in the graph. What’s up with these numbers? Why can’t they be parsed?
Any thoughts? I’m hoping for a real head-slapper “geez I’m dumb” kind of answer! But any answer will do.
Thanks!
I think the clue may be the fact the strange behavior only appears for the last item in the list. So for System Load messages it’s split(’:’)[3] and for others its split(’:’)[1]. The last item of the received string may have an unseen terminating character. That character is non-numeric so it prevents the float filter from converting the balance of the string to a number (it reports its default value of 0.0).
@123 Good clue, thanks. I have been able to test so far that for the value “11632119808” the length function returns 12. That’s one extra character!
So I truncated three characters off the end and lost only the “08.” My first attempt failed at math on the resulting value failed once again (“unknown,” meh), but this is a promising development and I can poke around a little more.
@123 Once again, thanks for your help. If I peel off that one last mystery invisible character (truncate by length-1) then everything seems to work!
Case closed. (Though it does seem the jinja2 “float” converter is needlessly sensitive here.)
I have prepared basic template and configuration for collectd data transferred from OpenWRT:
Do you have a tutorial on how to make it work?
Very old thread, but I thought I’d add (to hopefully solve the mystery): the payloads collectd pushes to MQTT are null terminated. So, for example, “1572919890.285:11632119808” is actually “1572919890.285:11632119808\0”. I believe you can get rid of it by some variation of:
{%- set value = value.split("\0")[0] -%}
