I’m trying to diagnose recurring Home Assistant crashes/freezes, possibly related to MQTT/AWTRIX.
System: Raspberry Pi 3 (64-bit), HAOS 18.2, Core 2026.6.4, ~925 MB RAM + 1 GB swap, Mosquitto add-on, Ulanzi/AWTRIX via MQTT.
The system sometimes becomes unresponsive within a few minutes until HA, SSH and even the Observer are no longer reachable and I have to power-cycle the Pi.
The HAOS kernel log confirms global OOM events, e.g.:
oom-kill: … global_oom … task=mosquitto
Out of memory: Killed process 4712 (mosquitto)
About 10 minutes later another OOM killed ttyd. I understand that Mosquitto being killed does not necessarily mean it caused the OOM.
The interesting part: After stopping Mosquitto completely, HA ran for more than 24 hours without a crash. Before that, crashes occurred repeatedly.
I use several AWTRIX MQTT automations. A complex HVV/public transport automation is currently my main suspect. I’m now testing with Mosquitto enabled but HVV and another complex sports automation disabled, then I’ll enable them one by one.
My questions:
- Has anyone seen AWTRIX/MQTT automations cause sudden memory spikes or message buildup leading to OOM?
- Is there a way in HAOS to record per-container/process memory usage shortly before an OOM? System Monitor only shows total RAM usage, and the SSH add-on doesn’t provide normal Docker access.
Thanks for any ideas!
