It’s the dropdown box below that one called “Config Parameter” that you need to set correctly. Not the Node Values.
The manual is useless and there is nothing listed on the zwavealliance website. This is rather poor form on the part of the manufacturer. Hopefully openzwave have some hints in that dropdown box for you.
@tom_l yes as you said I opened the dropdown of the “Config Prameter”. The image I attached is the dropdown list that openes when you click “Check Parameter”, but there isn’t a unit of measurement.
As you said there is nothing about it in the hint paper. I also mailed them but no reply.
