TM1637 and ESP - unable to print decimal point when projecting float number
Trivial problem - I’m using 8x using 7 segment displays connected to ESP8266 to project current data about my solar system. I was following this tutorial, which clearly explains that float values will have a dot based on the precision selected (in my case .1f or even .2f). I am happy with response time and the way how things work. Except for one small thing - I am unable to force displays to show the decimal point when projecting these float numbers.
I am capturing float values form esphome (e.g. 27.70000)
Here’s my problem:
it.printf(1, "%.1f",id(battery_voltage).state);
returns _ 277
it.printf(0, "%.1f",id(battery_voltage).state);
returns 27:7_
it.printf(0, "%.2f",id(battery_voltage).state);
returns 27:70
What am I doing wrong here?
Using a TM1637 Display without any decimal points maybe? :thinking:
each segment has a “dot” available. But that gave me idea to troubleshoot with static values…
edit: you are correct, sir… this is a “clock” module, that recognizes a “dot” as colon when used after second segment.
I’ll stick with integers for now then…
Interesting. The ESPHome docs for that display only mentions the colon (:) and no points :thinking:
To display the colon punctuation use the . in the colon place. (See clock example below)
Maybe it isn’t supported (yet) by the esphome component? Maybe raise a bug/feature request or hit the devs on the discord :speaking_head:
most likely I bought a module that (despite dot being visible) does not really support the punctuation… I tried experimenting with values like 1.1.1.1 or … , every time all I got was only 11:11 or nothing… So I guess it’s the hardware that does not work as expected.
