To-Do list card background is near-white
After reading this - Selection boxes unreadable after recent update
…and adding the three new elements to my theme, most things are back on track.
The To-Do list dash itself is fine, but the to-do list card which I have added to my frond-end dash, is still not corrected and I can’t find how to.
I have a feeling it’s with the card within HA rather than the dash theme, so I’m not sure how to correct this.
Catppuccin Macchiato:
  # Colors
  text: "#cad3f5"
  subtext1: "#b8c0e0"
  subtext0: "#a5adcb"
  overlay2: "#939ab7"
  overlay1: "#8087a2"
  overlay0: "#6e738d"
  surface2: "#5b6078"
  surface1: "#494d64"
  surface0: "#363a4f"
  base: "#24273a"
  mantle: "#1e2030"
  crust: "#181926"
  rosewater: "#f4dbd6"
  flamingo: "#f0c6c6"
  pink: "#f5bde6"
  mauve: "#c6a0f6"
  red: "#ed8796"
  maroon: "#ee99a0"
  peach: "#f5a97f"
  yellow: "#eed49f"
  green: "#a6da95"
  teal: "#8bd5ca"
  sky: "#91d7e3"
  sapphire: "#7dc4e4"
  blue: "#8aadf4"
  lavender: "#b7bdf8"
  # Header
  app-header-background-color: var(--mantle)
  app-header-text-color: var(--text)
  # Main Interface colors
  primary-color: var(--overlay0)
  light-primary-color: var(--primary-color)
  accent-color: var(--yellow)
  primary-background-color: var(--base)
  secondary-background-color: var(--base)
  # Text
  primary-text-color: var(--text)
  secondary-text-color: var(--subtext1)
  text-primary-color: var(--text)
  divider-color: var(--base)
  disabled-text-color: var(--overlay0)
  text-accent-color: var(--base)
  # Sidebar
  sidebar-background-color: var(--crust)
  sidebar-selected-background-color: var(--primary-background-color)
  sidebar-icon-color: var(--subtext0)
  sidebar-text-color: var(--subtext0)
  sidebar-selected-icon-color: var(--mauve)
  sidebar-selected-text-color: var(--mauve)
  # Buttons
  paper-item-icon-color: var(--subtext0)
  paper-item-icon-active-color: var(--primary-color)
  # States and Badges
  state-icon-color: var(--lavender)
  state-icon-active-color: var(--primary-color)
  state-icon-unavailable-color: var(--disabled-text-color)
  # Sliders
  paper-slider-knob-color: var(--blue)
  paper-slider-knob-start-color: var(--paper-slider-knob-color)
  paper-slider-pin-color: var(--paper-slider-knob-color)
  paper-slider-active-color: var(--paper-slider-knob-color)
  paper-slider-secondary-color: var(--blue)
  # Labels
  label-badge-background-color: var(--surface0)
  label-badge-text-color: var(--text)
  label-badge-red: var(--red)
  label-badge-green: var(--green)
  label-badge-blue: var(--blue)
  label-badge-yellow: var(--yellow)
  label-badge-gray: var(--overlay0)
  # Cards
  card-background-color: var(--surface0)
  ha-card-background: var(--card-background-color)
  ha-card-border-radius: "15px"
  ha-card-box-shadow: none
  paper-dialog-background-color: var(--overlay0)
  paper-listbox-background-color: var(--overlay0)
  paper-card-background-color: var(--card-background-color)
  # Switches
  switch-checked-button-color: var(--green)
  switch-checked-track-color: var(--surface2)
  switch-unchecked-button-color: rgb(--overlay0)
  switch-unchecked-track-color: rgb(--surface0)
  # Toggles
  paper-toggle-button-checked-button-color: var(--switch-checked-button-color)
  paper-toggle-button-checked-bar-color: var(--switch-checked-track-color)
  paper-toggle-button-unchecked-button-color: var(--switch-unchecked-button-color)
  paper-toggle-button-unchecked-bar-color: var(--switch-unchecked-track-color)
  # Table
  table-row-background-color: var(--primary-background-color)
  table-row-alternative-background-color: var(--secondary-background-color)
  data-table-background-color: var(--primary-background-color)
  mdc-checkbox-unchecked-color: var(--overlay0)
  # Dropdowns
  material-background-color: var(--primary-background-color)
  material-secondary-background-color: var(--primary-background-color)
  mdc-theme-surface: var(--primary-background-color)
  # Pre/Code
  markdown-code-background-color: var(--surface0)
  # Checkboxes
  mdc-select-fill-color: var(--surface0)
  mdc-select-ink-color: var(--primary-text-color)
  mdc-select-label-ink-color: var(--subtext1)
  mdc-select-idle-line-color: var(--primary-text-color)
  mdc-select-dropdown-icon-color: var(--secondary-text-color)
  mdc-select-hover-line-color: var(--accent-color)
  # Input
  input-fill-color: var(--secondary-background-color)
  input-dropdown-icon-color: var(--secondary-text-color)
  input-ink-color: var(--primary-text-color)
  input-label-ink-color: var(--secondary-text-color)
  input-idle-line-color: var(--primary-text-color)
  input-hover-line-color: var(--accent-color)
  input-disabled-ink-color: var(--disabled-text-color)
  input-disabled-line-color: var(--disabled-text-color)
  input-outlined-idle-border-color: var(--disabled-text-color)
  input-outlined-hover-border-color: var(--disabled-text-color)
  input-outlined-disabled-border-color: var(--disabled-text-color)
  input-disabled-fill-color: rgba(0, 0, 0, 0)
  # Toast
  paper-toast-background-color: var(--overlay0)
  # Colors
  error-color: var(--red)
  warning-color: var(--yellow)
  success-color: var(--green)
  info-color: var(--blue)
  state-on-color: var(--green)
  state-off-color: var(--red)
  ha-color-form-background: var(--card-background-color)
  ha-color-form-background-hover: var(--surface1)
  ha-color-form-background-disabled: rgba(0, 0, 0, 0)
