I’ve got a to do list, that I use to notify me of upcoming chores. I’ve used a few examples from elsewhere on this forum to make it work, but there’s something I can’t work out - when a task doesn’t have a due date, none of the sensors work.
Here is my config:
template:
- trigger:
- trigger: time_pattern
minutes: /1
- platform: state
entity_id: todo.chores
- service: todo.get_items
status: needs_action
response_variable: todo_list
- name: "To Do List - Today"
unique_id: todo_list_today
state: >
{%- set today = now().strftime('%Y-%m-%d')-%}
{%- set ns = namespace(result = []) -%}
{% set tasks_list = todo_list['todo.chores']['items'] %}
{%- for task in tasks_list -%}
{%- if task['due'].split('T')[0] == today -%}
{%- set ns.result = ns.result + [task['summary']] -%}
{%- endif -%}
{%- endfor -%}
{{ ns.result | count }}
attributes:
items: >
{%- endif -%}
{%- endfor -%}
{%- if ns.result is iterable -%}
{%- for item in ns.result %}
- {{ item }}
{%- endfor -%}
{%- endif -%}
This works fine as long as all tasks have a due date. When one doesn’t, it comes back as unavailable.
My questions are:
How can I make the above work when there is not due date?
Can I create a new sensor that only brings back the items where there is no due date?
When there is no due date, the code task['due'] will return null, so then calling split on it will cause an error - which is why you’re getting unavailable.
A simple way to avoid the error would be to provide a default value:
{%- if (task['due'] | default('')).split('T')[0] == today -%}
This would skip that task - if you wanted to include it instead you could just use default(today).
However, you don’t need to do this with a loop as selectattr will find the ones you want and ignore if missing:
{{ todo_list['todo.chores']['items']
| selectattr('due', 'eq', today)
| list | count
Actually the above will only work if you use due date not date/time. In that case you’d have to use selectattr('due', 'match', today + '*').
