Toggle a sliding menu per device instead of globally in Home Assistant?
Hi guys, I’m not too sure how to explain this, but the concept is very simple. I need a variable that can be triggered on and off to control the menu animation (a sliding bar showing and hiding) respectively when the variable is true or false.
I managed to do this, but the variable is from a helper, so it’s global. Because of that, every time I open or close the menu, it does it on all devices at the same time. Instead, I would like the menu to open or close only on the device I’m currently using.
To achieve this, I tried using browser mode, but I can’t seem to make it work. The only thing I managed to do is create a different menu using a pop-up, but I don’t really like using pop-ups for my main menu.
Can anyone assist or suggest where I might find an example with a similar function?
Check out expander-card which supports actions to expand / collapse.
Thanks Darryn, Are those only visible in the device in use?
Yes. That is correct.
I have got this menu set up but is using global variable on helper. Do you believe I can’t do any change to make the open/close menu visible only on the device in use rather than on all devices?
        # MENU BUTTON (always visible)
        - type: icon
          entity: input_boolean.input_boolean_floorplan3_move
          icon: mdi:menu
          style:
            '--iron-icon-height': 1vw
            '--iron-icon-width': 1vw
            '--paper-item-icon-active-color': '#ffff66'
            '--paper-item-icon-color': darkgrey
            border-radius: 100%
            top: 5%
            transform: scale(1.2)
            width: 6vw
            height: 6vw
            background: none
            border: none
            box-shadow: none
            display: flex
            justify-content: center
            align-items: center
            padding: 0.5vw # optional, improves touch feel
            z-index: 3
          card_mod:
            style: |
              :host {
                transition: left 0.7s ease-in-out;
                left: {{ '16%' if states('input_boolean.input_boolean_floorplan3_move') == 'on' else '-1%' }};
                position: absolute !important;
          tap_action:
            action: toggle
#########################    MENU BAR    #########################
        - type: image
          image: /local/ndr_floorplan/sidebar/sidebar_xl.png
          style:
            height: 100%
            #left: 11.73828125%
            top: 50%
            width: 23.4765625%
            z-index: 2
          card_mod:
            style: |
              :host {
                left: {{ '11.73828125%' if states('input_boolean.input_boolean_floorplan3_move') == 'on' else '-6%' }};
          tap_action:
            action: none
#########################    OVERLAYER    #########################
        - type: image
          image: /local/ndr_floorplan/sidebar/sideShadow.png
          tap_action:
            action: call-service
            service: input_boolean.turn_off
              entity_id: input_boolean.input_boolean_floorplan3_move
          style:
            height: 200%
            left: 0%
            opacity: 0.9
            top: 0%
            z-index: 1
          card_mod:
            style: |
              :host {
                /* no transition here */
                width: {{ '200%' if states('input_boolean.input_boolean_floorplan3_move') == 'on' else '0%' }};
#########################    LOGO    #########################
        - type: image
          image: /local/Logo.png
          style:
            #left: 12%
            top: 7%
            width: 8%
            z-index: 10
          card_mod:
            style: |
              :host {
                left: {{ '12%' if states('input_boolean.input_boolean_floorplan3_move') == 'on' else '-6%' }};
#########################    HOME    #########################
        - type: image
          image: /local/ndr_floorplan/sidebar/home_on.png
          style:
            border-radius: 5vw
            box-shadow: '0px 0.2vw 0.8vw 0px rgba(0,0,0,0.1)'
            #left: 11.7%
            top: 26%
            width: 20.5078125%
            z-index: 2
          card_mod:
            style: |
              :host {
                left: {{ '11.7%' if states('input_boolean.input_boolean_floorplan3_move') == 'on' else '-5%' }};
          tap_action:
            action: navigate
            navigation_path: /ndr-floorplan/home
#########################    DEVICES    #########################
        - type: image
          image: /local/ndr_floorplan/sidebar/devices_off.png?v=1
          style:
            #left: 11.7%
            top: 34%
            width: 20.5078125%
            z-index: 2
          card_mod:
            style: |
              :host {
          tap_action:
            action: navigate
            navigation_path: /ndr-floorplan/devices
this is the side triggered to open and close the menu
