I have a device relay that I need to toggle every 2 hours, so I’ve set up an automation for that purpose. However, since the device is located in a remote area of the house, there are times when it goes offline. To address this issue, I have included a delay in the automation, ensuring that it waits for the device to come back online before toggling it.
However, I’m concerned about what would happen if the device doesn’t come back online before the next scheduled trigger. Will two instances of the automation run simultaneously? How can I prevent this from happening? Is there a better approach to achieve my goal?
You decide this with the ‘mode’ setting (if you’re using the UI it’s under the 3 dot menu as ‘change mode)’. The default is single, which means the automation will only run one at a time (and if it triggers again while it’s currently running, it won’t run again).
alias: example
- platform: state
entity_id: binary_sensor.toggler_schedule
- 'on'
- 'off'
to:
- 'off'
- 'on'
- platform: state
entity_id: switch.your_switch
- 'unavailable'
condition: []
- service: "switch.turn_{{ states('binary_sensor.toggler_schedule') }}"
If the switch becomes unavailable when it disconnects from the network, the moment it reconnects and its state changes, the automation sets it to the correct state based on whether the current time is within an off period or on period (where the period is 2 hours).
