This will reset the 10sec timer every time the button is pressed. It will also allow you to make all the presses a second apart without triggering the command before.
[{"id":"d1f64219.aca37","type":"inject","z":"f80b6c338afd5483","name":"button","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":370,"y":3840,"wires":[["58d816b8.3f26f8","3a612207206b8a6f"]]},{"id":"58d816b8.3f26f8","type":"counter","z":"f80b6c338afd5483","name":"","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":1,"x":580,"y":3840,"wires":[["eb3583b1.0a3a8"]]},{"id":"eb3583b1.0a3a8","type":"switch","z":"f80b6c338afd5483","name":"press count","property":"count","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"}],"checkall":"true","repair":false,"outputs":4,"x":740,"y":3840,"wires":[["d5183eef25a93234"],["a6f546274dc48ccd","40b526951783a776"],["9c5e452e7518bd0d","3edd44ad4db086ac"],["6ccceb3f1c15866c","b7e017f96177c113"]]},{"id":"c63f0340.f2ce7","type":"change","z":"f80b6c338afd5483","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":3920,"wires":[["58d816b8.3f26f8"]]},{"id":"a0701bed.f99bd8","type":"debug","z":"f80b6c338afd5483","name":"2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1170,"y":3920,"wires":[]},{"id":"100574f7.d40eeb","type":"debug","z":"f80b6c338afd5483","name":"3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1170,"y":4020,"wires":[]},{"id":"b718f26ca08505e6","type":"debug","z":"f80b6c338afd5483","name":"4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1170,"y":4120,"wires":[]},{"id":"74258e63ecfbaeec","type":"debug","z":"f80b6c338afd5483","name":"1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1170,"y":3820,"wires":[]},{"id":"3a612207206b8a6f","type":"trigger","z":"f80b6c338afd5483","name":"","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"10","extend":true,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":430,"y":3920,"wires":[["c63f0340.f2ce7"]]},{"id":"d5183eef25a93234","type":"delay","z":"f80b6c338afd5483","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1000,"y":3820,"wires":[["74258e63ecfbaeec"]]},{"id":"40b526951783a776","type":"delay","z":"f80b6c338afd5483","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1000,"y":3920,"wires":[["a0701bed.f99bd8"]]},{"id":"a6f546274dc48ccd","type":"change","z":"f80b6c338afd5483","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":3880,"wires":[["d5183eef25a93234"]]},{"id":"3edd44ad4db086ac","type":"delay","z":"f80b6c338afd5483","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1000,"y":4020,"wires":[["100574f7.d40eeb"]]},{"id":"9c5e452e7518bd0d","type":"change","z":"f80b6c338afd5483","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":3980,"wires":[["40b526951783a776"]]},{"id":"b7e017f96177c113","type":"delay","z":"f80b6c338afd5483","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1000,"y":4120,"wires":[["b718f26ca08505e6"]]},{"id":"6ccceb3f1c15866c","type":"change","z":"f80b6c338afd5483","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":4080,"wires":[["3edd44ad4db086ac"]]}]
