Too Good To Go integration
Hello, has anyone integrated the TooGoodToGo app into the home assistant?
The only custom component is the one proposed by Chouffy (Chouffy · GitHub)?
This component works but is not optimized. If you set too little refresh time you will be banned from the site.
Well don’t set it that low then.
also exists.
But a too little refresh time is also the same problem.
This is done on the TGTG side…
