To help the TotalConnect integration report hardware model and ID into Home Assistant better, I need users to participate in a “device census” to gather information about the various hardware that is used with TotalConnect.
First I need your physical device model and model/version number. This is from the a label on the hardware, or perhaps from your user guide or other documentation. Something like model “Lynx Touch” and model ID “L7000”.
Second, download your Diagnostics for TotalConnect from within Home Assistant. One way is to click on your alarm panel, hit the three vertical dots and then Device Info. You should see a link for Download Diagnostics.
You can search for the info as described below, or just attach or cut/paste your whole diagnostic file.
You may see multiple devices listed in your diagnostic file. I am primarily interested in the alarm panel, which will be the longest device entry, but feel free to report the other devices as well. I need the following for each device (if not provided, say “null”):
a) class_id
b) security_panel_type_id
c) PanelType
d) PanelVariant
Post a response that looks something like this:
Model: Lynx Touch
Model ID: L7000
class_id: 1
security_panel_type_id: 12
PanelType: 12
PanelVariant: 1
