Touch display installation and dashboard display
Hello everyone! I’m new to this topic and need some support setting up the touch display. The HA server is running smoothly. I bought the MageDok T090A monitor and connected the Raspberry Pi to it. However, I can’t seem to figure out two things, no matter how much I research.
  1. How do I activate the touch monitor? I found instructions via the Pi config menu, but I can’t figure it out.
  2. How do I get my desired dashboard to automatically display when the Raspberry boots up?
If there are any videos or posts on this, please just link them. I can’t find anything.
Thank you and best regards,
Tobias
HA is a server you need a web thing (browser) to display it on port its IP address : 8123
I assume the pi you talk of is the one running HAOS. if so this does not suuport running a web browser. You will need to run a very different setup to do this, or use a different device to run the monitor. Look at running HA in a container on whatever OS you choose.
Here is a pi400 running HA in kiosk mode. Followed the tutorial by Mark Watt Tech
