Touch switch Yvvpiupu configuration
I managed to flash an esphome file onto a smart switch with touch, and it works properly except the touch.
Here is my yaml:
esphome:
  friendly_name: Kitchen Sink Light
bk72xx:
  board: cb3s
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "XXX"
ota:
  - platform: esphome
    password: "XXXX"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Kitchen-Sink-Light"
    password: "XXX"
captive_portal:
#uart:
#  rx_pin: GPIO24 #RX1
#  tx_pin: GPIO26 #TX1
#  baud_rate: 9600
#tuya:
status_led:
  pin:
    number: GPIO11
    inverted: true
# Example configuration entry
switch:
  - platform: gpio
    pin: GPIO06
    inverted: true
  - platform: gpio
    pin: 07
#    on_turn_on:
#      then:
#        switch.turn_on: "blue_led"
#    on_turn_off:
#      then:
#        switch.turn_off: "blue_led"
#  - platform: gpio
#    pin: 11
#    name: "Blue LED"
#    id: blue_led
#    inverted: true
  - platform: gpio
    pin: 09
    on_turn_on:
      then:
        switch.turn_on: "green_led"
    on_turn_off:
      then:
        switch.turn_off: "green_led"
binary_sensor:
  - platform: gpio
    pin:
      number: 14
      mode:
        input: true
        pullup: true
      inverted: true
    on_click:
      min_length: 150ms
      then:
        switch.toggle: outlet
    on_double_click:
      then:
        - switch.toggle: light
#.    CANT BE THIS BECAUSE NOT CONNECTED TO THE UC
#  - platform: gpio
#    pin:
#      number: 10
#      mode:
#        input: true
#        pullup: false
#      inverted: true
#    name: Light
#    on_click:
#      min_length: 50ms
#      then:
#        switch.toggle: light
Pinout: CB3S - LibreTiny
The pins P26 and P24 on the cb3s are connected to the IC to the right (via the two vias to the bottom right of that ic marked A102C; which in turn is also connected to the touch sensitive areas outlined in white silkscreen).
Wondering if anyone has any thoughts on how to get this touch setup to work?
Happy to test things out.
Thank you
Edit: added pics
Figured it out!
Turns out that chip must be some sort of capacitive sensor, it just relays the touches to the pins of the cb3s.
As a result, there’s a second touch button that can be used!
If one is feeling a bit adventurous, there are a few pads that seem like they could accommodate the respective LEDs too!
Pretty happy with this, I got a bonus button for the outlet I was already happy with.
Sweet!
here’s my final YAML:
status_led:
pin:
number: GPIO11
inverted: true
switch:
- platform: gpio
pin: GPIO06
inverted: true
- platform: gpio
pin: 07
- platform: gpio
pin: 09
on_turn_on:
then:
on_turn_off:
then:
binary_sensor:
- platform: gpio
pin:
number: 14
mode:
input: true
pullup: true
inverted: true
on_click:
min_length: 50ms
then:
- platform: gpio
pin:
number: 24
mode:
input: true
pullup: false
inverted: true
on_click:
min_length: 50ms
then:
- platform: gpio
pin:
number: 26
mode:
input: true
pullup: false
inverted: true
I hope this helps someone.
Cheers!
One more thought:
There are even solder points for a 3rd relay, and its respective diode; so you could upgrade this entirely if you had the components…
For the second touch button, it doesn’t work when the cover is put back on; presumably because there is no button cutout at that area on the metallic sticker on the backside of the glass. So this could work if you peeled off the sticker and replaced it with something else (or not) or cut a circle similar to the top button that is also cut out.
I’m not going to use this button unless I find a way to make it all look nice.
Cheers!
edit: added pic
