I have a few towel warmers at home and I created several scripts and automations to make sure that they run according to a schedule. As I created something in regards to controlling dehumidifiers and it was useful for its purpose, I decided that I would do the same for the towel warmers (much simpler) so I would be able to:
connect a towel warmer to a plug
set the daily start and end hour of the towel warmer use, controlling the switch of the plug
define the minimum power threshold detected by the plug so it can detect if it’s running, turned off or malfunctioning
define how much time can I run a towel warmer manually (outside of scheduled hours) so that I don’t forget about turning it off (manually)
You can expect that the usual towel warmers use something between 200 and 500W. That’s about the opposite of a high load. Typical plugs are mostly rated somewhere from 2000 - 3500W (230V, Schuko type)
As I stated in the other thread, I am no electrical engineer.
It was mostly as a warning and someone mentioned that even USB stuff can kill a poorly made plug.
