Hello everyone.
I used to have normally my Toyotomi A/c’s working in home assistant with GREE component. I retrieve the tokens by emulate an android device and root the directory for extract the database.
Recently, one of the aircons lost from hassio probably when i updated and now i can not retrieve back the token cause the EWPE app probably decrypts the datebase so is not readable.
Any suggestion on that? The database can be found but when i retrieve it and try to read with sqlite or other programs, an error appears that this is not .db file.
Thank you for reading this.
