TP-Link Deco not connecting X20s
I go to add integration, add the TP-Link Deco, change the IP to 192.168.68.1 (Which is my IP) add my password and click submit.
The submit changes to a lopping gif, that lasts about 2 minutes, it then come back with the error below.
The only Errors in the log are
This error originated from a custom integration.
Logger: custom_components.tplink_deco
Source: custom_components/tplink_deco/config_flow.py:81
Integration: TP-Link Deco (documentation, issues)
First occurred: 13:53:26 (1 occurrences)
Last logged: 13:53:26
Error testing credentials:
I get a invalid authentication.
Though I’m putting the right password.
Does this integration work for all decos?
I have a deco x20 and it doesnt have a Web portal. The router can only be managed through the app. So maybe this is what’s causing the issue?
Any help would be greatly appreciated
Did anyone get a response on this as I have the same issue and my Deco’s work fine so seem to be with the integration rather than the Deco’s themselves?
No, I gave up and now use the ping, to check if they are up or not.
