Ok Finally figured this out
Since My system will not auto discover the plug or switch, I had to add them manually for which I added them under Switch: the HS200 was perfectly happy to reside under, the KP200 was not happy about it so it would not function proper,
I decided to try to add it under strip: and restarted the server, and boom both switches on the KP200 are working and reporting.
This is a example in configuration file in case anybody is experiencing the same type of issue
this is a Venv type install of Home assistant
tplink:
discovery: false
switch:
- host: IP of HS200
strip:
- host: IP of KP200
