TPLINK KP115 Negative values of energy
am trying to use thr kp115 for energy monitoring keep getting negative values any advice there is a live wattage value sencer but am unable to use see that in energy setup tab
Hello, as mentionned, the sensor needs to follow specific rules/characteristics but the first one is to be expressed in kWh… so a live watt sensor will not work. You have to create a new sensor which will convert that instant value to an energy by hour, day, week, or month… depending on what you want to track and display.
thank any tutorials on how to do this am very new to this and keep going around in circles
I found that I had to remove the Tp-Link integration and add it back in again for energy consumption to work properly. After I did so, I got a whole new set of sensors - about 7 for each device, including today’s consumption and total consumption that can be added to the energy panel.
that what ive added but keep getting negative values
