Tplink_LTE Integration compatibility with TP-Link MR600
Im having troubles trying to setup the Tplink_LTE integration with my TP-link MR600 LTE router/modem with the latest firmware: 1.2.0.0.9.1! does anyone knows if its compatible?
my configuration.yaml:
 tplink_lte:
   - host: 192.168.8.1
     password: myrouterpassword
     notify:
       - name: sms1
         recipient: "+myphonenumber"
my log:
2020-09-07 18:24:53 WARNING (MainThread) [homeassistant.components.tplink_lte] Could not connect to 192.168.8.1. Will keep trying
Same problem here.
Did you find a solution to this?
Same here, Current Version: 2021.5.2 Have just purchased the MR600 and tried this Integration without luck. No need for username in the config?
Did anyone find a solution ?
I am using a MR600 (V2) but I have a different error message (the notify service exist but cannot send any message)… Anyone has the same problem ?
2023-03-14 13:33:56.267 ERROR (MainThread) [homeassistant.components.tplink_lte.notify] No modem available
Update: finally I used this to send SMS (that I installed in /config/www/tp-link-modem-router)
Pre-requisit: install “yarn” and “nodejs” (I am using Hass Os, so I installed these in the SSH terminal as packages)… To send SMS you have to run the command in a shell script into a SSH session… Working fine sofar… Here is the shell-command (“arguments” contains the phonenumber and the text to be sent separated with a “,” :
send_sms: ssh root@HA_IP_ADDRESS -o 'StrictHostKeyChecking=no' -i /config/.ssh/id_rsa '/bin/bash /config/private_shell_scripts/send_sms.sh "{{ arguments }}"'
send_sms.sh is (the data related to the modem (ip address, username/password) is declared in config.json (see Github -Plewin tutorial for more details)) :
#!/bin/bash
# extract data from the arguments passed from Home Assistant
args=$1
phonenumber=${args%%,*}
args=${args#*,}
message=""${args%%,*}""
cd /config/www/tp-link-modem-router
./sms-send.js $phonenumber "$message"
can you create an automation?
An automation to do what ? Can you clarify ?
I can send SMS from Home Assistant using automation script…
