Tplink switch and light entity unavailable
I’m having issues with the tplink component and have been since it was refactored a few releases back. I’m running the latest version.
I have a number of switches and smart bulbs. I find the last device listed in the configuration or discovered shows as entity unavailable. I have tried putting the devices in the config, leaving them out, setting discovery true or false and always get a similar result. I note that the smart bulbs don’t show in the integration section of the UI
tplink:
discovery: true
light:
- host: 192.168.0.76
- host: 192.168.0.77
switch:
- host: 192.168.0.61
- host: 192.168.0.72
- host: 192.168.0.73
any help gratefully appreciated
Matt
I am having the same problem.
@mhaylock UPDATE - it’s still early but I made some changes to my config and now have all of my TP-Link devices available again. I manually entered them in my config like you have in yours but then I went and deleted all of the corresponding entries from the known_devices.yaml file. Restart HA and you should see everything communicating properly again. Now let’s just hope it lasts…
