Tplink switchs - can i disable error individually for module query 'get_matter_setup_info
hi i got these new Kasa Tplink Matter Switchs dimmers…
1st question why did i need an account to set them up?
and 2nd i get these errors… i have the internet shut off to the IoT devices and i turned off cloud diagnostic. as i dont want it connecting to the internet
but i seeing these errors any way i can fix it?
Logger: kasa.smart.smartdevice
Source: components/tplink/coordinator.py:78
First occurred: March 2, 2025 at 7:29:56 PM (22 occurrences)
Last logged: 2:12:07 AM
Error querying 192.168.20.162 individually for module query 'get_matter_setup_info' after first update: ('Unable to query the device: 192.168.20.162: ', TimeoutError())
Error querying 192.168.20.162 for modules 'Time, Cloud, DeviceModule, LightPreset, LightTransition, Matter' after first update: ("Device connection error: 192.168.20.162: Cannot connect to host 192.168.20.162:80 ssl:<ssl.SSLContext object at 0x7f659ac4b140> [Connect call failed ('192.168.20.162', 80)]", ClientConnectorError(ConnectionKey(host='192.168.20.162', port=80, is_ssl=False, ssl=<ssl.SSLContext object at 0x7f659ac4b140>, proxy=None, proxy_auth=None, proxy_headers_hash=None), OSError(113, "Connect call failed ('192.168.20.162', 80)")))
Error querying 192.168.20.162 individually for module query 'get_device_time' after first update: ("Device connection error: 192.168.20.162: Cannot connect to host 192.168.20.162:80 ssl:<ssl.SSLContext object at 0x7f659ac4b140> [Connect call failed ('192.168.20.162', 80)]", ClientConnectorError(ConnectionKey(host='192.168.20.162', port=80, is_ssl=False, ssl=<ssl.SSLContext object at 0x7f659ac4b140>, proxy=None, proxy_auth=None, proxy_headers_hash=None), OSError(113, "Connect call failed ('192.168.20.162', 80)")))
Error querying 192.168.20.162 individually for module query 'get_device_usage' after first update: Error querying device: 192.168.20.162: TIME_ERROR(-1601) for method: get_device_usage (error_code=TIME_ERROR)
Error processing Time for device 192.168.20.162, module will be unavailable: get_device_time for Time (error_code=INTERNAL_QUERY_ERROR)
Logger: homeassistant.components.tplink.coordinator
Source: helpers/update_coordinator.py:412
integration: TP-Link Smart Home (documentation, issues)
First occurred: March 2, 2025 at 7:30:20 PM (10 occurrences)
Last logged: 2:19:41 AM
Error fetching 192.168.20.200 data: Unable to communicate with the device update: Unable to connect to the device: 192.168.20.200:9999: [Errno 111] Connect call failed ('192.168.20.200', 9999)
Error fetching 192.168.20.254 data: Unable to communicate with the device update: Unable to connect to the device: 192.168.20.254:9999: [Errno 111] Connect call failed ('192.168.20.254', 9999)
Error fetching 192.168.20.237 data: Unable to communicate with the device update: Unable to connect to the device: 192.168.20.237:9999: [Errno 111] Connect call failed ('192.168.20.237', 9999)
Error fetching 192.168.20.162 data: Unable to communicate with the device update: get_device_info not found in {'get_device_time': <SmartErrorCode.INTERNAL_QUERY_ERROR: -100001>, 'get_device_info': <SmartErrorCode.INTERNAL_QUERY_ERROR: -100001>, 'get_device_usage': <SmartErrorCode.INTERNAL_QUERY_ERROR: -100001>, 'get_matter_setup_info': <SmartErrorCode.INTERNAL_QUERY_ERROR: -100001>} for device 192.168.20.162
Error fetching 192.168.20.195 data: Unable to communicate with the device update: Unable to connect to the device: 192.168.20.195:9999: [Errno 111] Connect call failed ('192.168.20.195', 9999)
or is it a mistake to gottten the kasa tplink matter switchs?
or is there a way to disable the error from coming up etc
