Track repetitive tasks with NFC tags
Hey @rfep2016 , I’m getting the same negative days_since_last_completed value because the helper stores the due date instead of the last completed date. Could you fix it?
BTW, @nwithan8 , thanks for the blueprint, it’s awesome
Ok, I was able to fix it with a simple change. There was a bug when the date tracker was being updated. The correct code is the following:
sequence:
          - alias: Update date tracker to next due date
            entity_id: input_datetime.date_the_plant_was_watered
              datetime: |
                {% if rolling_completion %}
                  {% set last_date = states(date_tracker) | as_datetime %}
                  {{ last_date.date() + timedelta(days=task_interval) }}
                {% else %}
                  {{ now().date() }}
                {% endif %}
            action: input_datetime.set_datetime
Note that when rolling_completition is false, we need to set date as today date.
Thanks for the debugging help, all. Seems I confused myself and was sometimes storing the past last completed date in the date helper, while other times storing the next future due date. I believe I’ve cleaned up the logic and am storing/calculating things correctly now. Blueprint is updated above and via the import link.
Since this update the automation broke. Getting the following error:
 Error rendering variables: UndefinedError: 'str object' has no attribute 'date'
Also, with the change I did earlier, I had the next date set in the helper and this gave me an easy overview of upcoming tasks. I reverted the update for now.
Welp.
Thanks for letting me know, I’ll take a look ASAP
Hey, I haven’t been able to recreate this issue on my end. I updated the blueprint with some guard clauses, but they really shouldn’t be necessary. I might recommend deleting and recreating the datetime helper you’re using for this automation, as it might contain an invalid date in it, that’s all I can think.
Ah, that might be the case: my helpers contain a date in the future whilst you now need an date in the past?
Weird occurence:
Logger: homeassistant.components.automation.clean_robot
Source: components/automation/__init__.py:701
integration: Automation (documentation, issues)
First occurred: 6:46:31 PM (22 occurrences)
Last logged: 7:00:08 PM
Error rendering variables: TypeError: unsupported operand type(s) for -: 'str' and 'datetime.date'
Here is my helper, I tried date and Date&Time
Alright, I think I got it now. I did almost a full rewrite of the logic. Turns out the issue was string vs datetime vs date variable types, that are hard to debug when the “Templates” tool in Home Assistant simply shows the string representation of any variable.
The automation has been updated accordingly.
Seems to be working perfectly, thank you for your amazing work.
