Track Water Usage in Energy Dashboard
I have a Home Assistant entity that tracks water usage in US gallons. I would love to track water usage within the Energy Dashboard. I assume I need to create a sensor that uses total_increasing, but I’m not 100% sure. Does anyone have a sample sensor device that enables the Water Meter in the Energy Dashboard for a single entity that tracks US gallons by incrementing the entity value as water is being used?
Is it even impossible to add water monitoring to the energy dashboard using a Home Assist device that tracks US gallons by incrementing the entity value as water is being used?
Yes.
So what’s your issue? Are you having trouble getting your existing sensor to be selectable for the Energy Dashboard? What integration is it from? Need more info to be able to help.
