Newbie here: I have an external IP address pinging my mosquitto broker integrated with Home Assistant in a Raspberry PI.
When I check the origin, it points toward ‘hassio’ but the MAC address is not recognised anywhere. What can I do next to identify and remedy the constant pinging of my mosquitto broker?
NathanCu
(Nathan Curtis)
September 13, 2022, 11:43pm
2
172.30 is within the 172.16.x.x/16 private address space (meaning it’s internal) its probably the vlan used for your container installation between your various containers or addons. Look there
nickrout
(Nick Rout)
September 13, 2022, 11:58pm
3
Are you using HAOS? You can type
ip addr|less
and get all of your addresses. The mac address is probably something made up by docker.
EDIT In fact it is the same as mine
➜ ~ arp 172.30.32.2
Address HWtype HWaddress Flags Mask Iface
hassio ether 02:42:ac:1e:20:02 C hassio
nickrout
(Nick Rout)
September 14, 2022, 12:09am
4
It kinda has to keep in touch with the broker
avd706
(Avd706)
September 14, 2022, 2:48am
5
I get spammed by that ip, but look at the bottom, that ip is not on my lan, and the port is not open to the internet.
nickrout
(Nick Rout)
September 14, 2022, 3:07am
6
That last ip address is certainly not from your LAN
nick@media:~$ nslookup 64.225.14.92
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
92.14.225.64.in-addr.arpa name = monitoring.internet-measurement.com.
NathanCu
(Nathan Curtis)
September 14, 2022, 3:39am
7
Agreed. Whatever it is, it’s also managed to get it’s IP logged on a couple honeypot sites… Which means…
…if that is not your intended routing, you need to verify your router’s port forwarding and UPnP settings to see about any holes punched in sending 1883 inbound to your HA box.
Something allowed that blank user login attempt in.
nickrout
(Nick Rout)
September 14, 2022, 4:30am
8
Back to the internal address, you can find out for sure which container it comes from with docker network
➜ ~ docker network ls
NETWORK ID NAME DRIVER SCOPE
a200b79c6ace bridge bridge local
363cd2cd3d39 hassio bridge local
d7db0cca0ad2 host host local
295c24907a73 none null local
OK so I have 4 networks, lets start by looking at the most obvious suspect
docker network inspect hassio
oops that’s a bit long, lets try
➜ ~ docker network inspect hassio|grep 172.30.32.2 -B4 -A1
"b91a231485ed5b3511a3f8feb3fff44b4f778073065fa6da8db0b0e68ad3676e": {
"Name": "hassio_supervisor",
"EndpointID": "873893c0d8670d76052f7d5d8d6cab942206fb9b59c549d9784e36f542c801b9",
"MacAddress": "02:42:ac:1e:20:02",
"IPv4Address": "172.30.32.2/23",
"IPv6Address": ""
As can be seen, that address is from the supervisor container (on my system anyway.)
Thank you all for the troubleshooting. Here is a lengthier explanation that hassio pings the mosquitto broker. @frenck spells out “That is the supervisor checking if the add-on is still responding as part of a health check. This is expected, not a bug and actually good.”
opened 05:32AM - 08 Jun 21 UTC
closed 07:20AM - 08 Jun 21 UTC
integration: mqtt
### The problem
in my home assistant mosquito add-on, an unknown client no clie… nt id is connecting and disconnecting as a loop forever
the IP address of the client looks like a docker container IP address (172.30.32.2). my network address is 192.168.0.1 , but I can't find any what container is trying to connect .pleas help me
### What is version of Home Assistant Core has the issue?
core-2021.6.2
### What was the last working version of Home Assistant Core?
core-2021.4.0
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
MQTT
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/mqtt/
### Example YAML snippet
```yaml
logins:
- username: user
password: 123456789
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
### Anything in the logs that might be useful for us?
```txt
1623126169: New connection from 192.168.0.110 on port 1883.
1623126169: New client connected from 192.168.0.110 as sonofflight1 (p2, c1, k30, u'hassio').
1623126184: New connection from 192.168.0.117 on port 1883.
1623126184: New client connected from 192.168.0.117 as keypad (p2, c1, k30, u'hassio').
1623126204: New connection from 172.30.32.1 on port 1883.
1623126204: New client connected from 172.30.32.1 as 2he2ok6kXNV7syNo9EIH5K (p2, c1, k60, u'hassio').
1623126373: New connection from 172.30.32.2 on port 1883.
1623126373: Socket error on client <unknown>, disconnecting.
1623126431: New connection from 172.30.33.5 on port 1883.
1623126431: New client connected from 172.30.33.5 as mqttjs_c8632349 (p2, c1, k60, u'hassio').
1623126493: New connection from 172.30.32.2 on port 1883.
1623126493: Socket error on client <unknown>, disconnecting.
1623126613: New connection from 172.30.32.2 on port 1883.
1623126613: Socket error on client <unknown>, disconnecting.
1623126733: New connection from 172.30.32.2 on port 1883.
1623126733: Socket error on client <unknown>, disconnecting.
1623126853: New connection from 172.30.32.2 on port 1883.
1623126853: Socket error on client <unknown>, disconnecting.
1623126973: New connection from 172.30.32.2 on port 1883.
1623126973: Socket error on client <unknown>, disconnecting.
1623127093: New connection from 172.30.32.2 on port 1883.
1623127093: Socket error on client <unknown>, disconnecting.
1623127213: New connection from 172.30.32.2 on port 1883.
1623127213: Socket error on client <unknown>, disconnecting.
1623127333: New connection from 172.30.32.2 on port 1883.
1623127333: Socket error on client <unknown>, disconnecting.
1623127453: New connection from 172.30.32.2 on port 1883.
1623127453: Socket error on client <unknown>, disconnecting.
1623127573: New connection from 172.30.32.2 on port 1883.
1623127573: Socket error on client <unknown>, disconnecting.
1623127693: New connection from 172.30.32.2 on port 1883.
1623127693: Socket error on client <unknown>, disconnecting.
1623127813: New connection from 172.30.32.2 on port 1883.
1623127813: Socket error on client <unknown>, disconnecting.
1623127933: New connection from 172.30.32.2 on port 1883.
1623127933: Socket error on client <unknown>, disconnecting.
1623127960: Saving in-memory database to /data/mosquitto.db.
1623128053: New connection from 172.30.32.2 on port 1883.
1623128053: Socket error on client <unknown>, disconnecting.
1623128173: New connection from 172.30.32.2 on port 1883.
1623128173: Socket error on client <unknown>, disconnecting.
1623128293: New connection from 172.30.32.2 on port 1883.
1623128293: Socket error on client <unknown>, disconnecting.
1623128413: New connection from 172.30.32.2 on port 1883.
1623128413: Socket error on client <unknown>, disconnecting.
1623128533: New connection from 172.30.32.2 on port 1883.
1623128533: Socket error on client <unknown>, disconnecting.
1623128653: New connection from 172.30.32.2 on port 1883.
1623128653: Socket error on client <unknown>, disconnecting.
1623128773: New connection from 172.30.32.2 on port 1883.
1623128773: Socket error on client <unknown>, disconnecting.
1623128893: New connection from 172.30.32.2 on port 1883.
1623128893: Socket error on client <unknown>, disconnecting.
1623129013: New connection from 172.30.32.2 on port 1883.
1623129013: Socket error on client <unknown>, disconnecting.
1623129133: New connection from 172.30.32.2 on port 1883.
1623129133: Socket error on client <unknown>, disconnecting.
1623129253: New connection from 172.30.32.2 on port 1883.
1623129253: Socket error on client <unknown>, disconnecting.
1623129373: New connection from 172.30.32.2 on port 1883.
1623129373: Socket error on client <unknown>, disconnecting.
1623129493: New connection from 172.30.32.2 on port 1883.
1623129493: Socket error on client <unknown>, disconnecting.
1623129613: New connection from 172.30.32.2 on port 1883.
1623129613: Socket error on client <unknown>, disconnecting.
1623129733: New connection from 172.30.32.2 on port 1883.
1623129733: Socket error on client <unknown>, disconnecting.
1623129761: Saving in-memory database to /data/mosquitto.db.
1623129853: New connection from 172.30.32.2 on port 1883.
1623129853: Socket error on client <unknown>, disconnecting.
1623129973: New connection from 172.30.32.2 on port 1883.
### Additional information
_No response_
nickrout
(Nick Rout)
September 14, 2022, 8:46pm
10
I would still be very worried about the connection from 64.225.14.92
PS if you want to pm me your external ip address I will check it for you. You need to trust me though (needless to say).
aceindy
(Aceindy)
September 14, 2022, 9:06pm
11
I’ll vouch for Nickrout, his intentions are good 🥹
avd706
(Avd706)
September 14, 2022, 9:14pm
12
Something is very wrong with my iptables.
Thanks for the offer.
nickrout
(Nick Rout)
September 14, 2022, 10:32pm
13
avd706:
No problem, and thanks for introducing me to that nice tool
Look out for upnp on you router/modem/whatever. Although most people think of upnp as a media technology, the protocol extends to allowing, on request, ports to be opened to the outside on a router. Maybe this happened here. @NathanCu mentioned this in post 7, but I thought it needed a little explanation. See (for example) here What is UPnP and why is it Dangerous?
avd706
(Avd706)
September 14, 2022, 11:07pm
14
