Trackr - Devices not showing up
Hey is anyone else using the Trackr Platform? I’ve added the Trackr Component to my Config file with username and password but no go on it pulling information down from Trackr’s Servers any thoughts?
Seeing anything in the logs? What devices do you have in your account?
I’ve not checked the logs yet but in my Trackr account I have 3 tags my iPhone and a iPad
Okay, well check your logs and if you see anything I’ll try to figure out what’s going on. I may need your help getting what the API is sending back for your account. Their API isn’t public so I have to reverse engineer it to make the trackr component so there could be all kinds of things preventing it from working.
I’m having the same issue with the device tracker not showing up for this even though it’s in my configuration. On .79.3 at this point. No errors in the log file. Did anyone get this resolved?
Mine is still working, I mentioned I would need help seeing what the API is returning since their API isn’t public there is no documentation. First thing to try is enabling debug logs and restarting and then send me a PM with your logs. If nothing stands out I would need to work with you to get the API response from your account so I can figure out what’s going on.
For what it’s worth, I see the following in the log:
2018-10-03 21:02:48 INFO (MainThread) [homeassistant.loader] Loaded device_tracker.trackr from homeassistant.components.device_tracker.trackr
