Trafikverket weather station integration, getting “Entity is currently unavailable”
first of all thank you all for a nice upgrades!
I am controlling the house floor heating as function of the outside temperature. I use Trafikverket weather stations as outside temperature input. I live between Fiskebäck and Åbro weather stations. So I use these weather stations to create a sensor that contains the mean value of the two weather stations air temparature, “(TF+TÅ)/2”.
I am running HA on a Raspberry Pi3B+ and I recently upgraded (from 2021.11.2 and OS6.6) to the following system setup:
I can read each weather station air temperature separately, see the temp diagram below:
mean outside temp
But I see that the “Mean Outside Temp” value is not valid anymore. It is at 0*C.
When reviewing the integration entities I recognize that some of the weather stations attributes are disabled by the integration, but not the “sensor.fiskeback_air_temperature” and “sensor.abro_air_temperature” that I use for the mean value.
So the separate air temperature values are presented, but not the “sensor.mean_outside_temp”.
I have the following in my configuration.yaml file:
# Adding sensors below this line! :)
    # Adding Sun related attribute sensors
    sensors:
      solar_angle:
        friendly_name: "Sun angle"
        unit_of_measurement: 'degrees'
        value_template: "{{ state_attr('sun.sun', 'elevation') }}"
      sunrise:
        value_template: "{{ state_attr('sun.sun', 'next_rising') }}"
    #    trafikverket_weatherstation
  - platform: trafikverket_weatherstation
    name: Trafikverket Fiskebäck
    api_key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    station: Fiskebäck
    monitored_conditions:
        - air_temp
        - road_temp
        - humidity
        - precipitation
        - wind_direction
        - wind_direction_text
        - wind_speed
        - wind_speed_max
        - precipitation_amount
        - precipitation_amountname
    station: Åbro
        - air_temp
        - road_temp
        - humidity
        - precipitation
        - wind_direction
        - wind_speed
        - wind_speed_max
    sensors:
   #     Medelvärdesbilda yttertemperaturer (Åbro och Fiskebäck)
      mean_outside_temp:
        friendly_name: 'Mean Outside Temp'
        unit_of_measurement: '°C'
        value_template: "{{(float(states('sensor.trafikverket_fiskeback_air_temperature')) + float(states('sensor.trafikverket_abro_air_temperature')))/2 | round(2)}}"
   #     Medelvärdesbilda windspeed (Åbro och Fiskebäck)
      mean_outside_windspeed:
        friendly_name: 'Mean Outside Windspeed'
        unit_of_measurement: 'm/s'
        value_template: "{{(float(states('sensor.trafikverket_fiskeback_wind_speed')) + float(states('sensor.trafikverket_abro_wind_speed')))/2 | round(2)}}"
   #     Medelvärdesbilda wind direction (Åbro och Fiskebäck)
      mean_outside_w_direction:
        friendly_name: 'Mean Outside w_direction'
        unit_of_measurement: '°'
        value_template: "{{(float(states('sensor.trafikverket_fiskeback_wind_direction')) + float(states('sensor.trafikverket_abro_wind_direction')))/2 | round(2)}}"
I reviewed the logs and found the following error:
TemplateError('TypeError: unsupported operand type(s) for /: 'str' and 'float'') while processing template 'Template("{{(float(states('sensor.trafikverket_fiskeback_air_temperature')) + float(states('sensor.trafikverket_abro_air_temperature')))/2 | round(2)}}")' for attribute '_attr_native_value' in entity 'sensor.mean_outside_temp'
07:12:31 – (ERROR) Template - message first occurred at 07:12:31 and shows up 3 times
Error while processing template: Template("{{(float(states('sensor.trafikverket_fiskeback_air_temperature')) + float(states('sensor.trafikverket_abro_air_temperature')))/2 | round(2)}}")
07:12:31 – (ERROR) helpers/template.py - message first occurred at 07:12:30 and shows up 3 times
I have copied the line:
to the Developers tools template and investigated.
I found that the parts:
{{states('sensor.trafikverket_fiskeback_air_temperature')}}
{{states('sensor.trafikverket_abro_air_temperature')}}
booth include “unknown” and that the complete line:
does not even “compute” however it was computing fine in the HA 2021.11.2 and OS6.6 setup.
I have tried to rearrange and altered the line creating the "sensor.mean_outside_temp” but it seems I
can unfortunatly not figure out how to change the line based on the error message and what is the root cause to the issue.
So I tried to minimize the challenge to below line, in order to find the root cause.
      mean_outside_temp:
        value_template: "{{states('sensor.trafikverket_fiskeback_air_temperature')|float}}"
This is not creating any errors but the "sensor.mean_outside_temp” is not presenting the fiskeback_air_temperature.
Because the
is still delivering “unknown”.
I am unfortunatly out of ideas, anyone else that has any ideas?
I wanted to make a good topic explaination and it became a little long, sorry for that.
Br Christian
I found the root cause to the problem.
After the HA update, the sensor name is not: sensor.trafikverket_fiskeback_air_temperature any more, it is sensor.fiskeback_air_temperature !
The correct code is below.
    sensors:
      solar_angle:
      sunrise:
    station: Fiskebäck
        - air_temp
        - road_temp
        - humidity
        - precipitation
        - wind_direction
        - wind_speed
        - wind_speed_max
    station: Åbro
        - air_temp
        - road_temp
        - humidity
        - precipitation
        - wind_direction
        - wind_speed
        - wind_speed_max
    sensors:
      mean_outside_temp:
        value_template: "{{(float(states('sensor.fiskeback_air_temperature')) + float(states('sensor.abro_air_temperature')))/2 | round(2)}}"
        value_template: "{{(float(states('sensor.fiskeback_wind_speed')) + float(states('sensor.abro_wind_speed')))/2 | round(2)}}"
        value_template: "{{(float(states('sensor.fiskeback_wind_direction')) + float(states('sensor.abro_wind_direction')))/2 | round(2)}}"
Now it works again.
Happy holidays!
BR Christian
