Trakt Scrobbler From Media Player
Let me start by saying, I am no coder and a lot of what's here I don't understand which goes to prove that LLMs can be useful. :wink:
I wanted to be able to scrobble what was being played on an Apple TV to Trakt (which is a great thing for me and many others) to track progress etc and there was noting out there. Writing it myself wasn't happening so using an LLM was my only option.
After several weeks, lots of testing and messing about I have it working... mostly.
This works for ATV, it may work for other media players, I don't know and I don't use any others so I can't test it but, I don't see why it wouldn't as it gets the media playing info from Home Assistant then feeds that to Trakt.
There are limitations that I've not yet found a way around.
For some shows it has to "guess" the episode as the media player isn't exposed to that, this can be flaky.
Same with some shows/movies, if an exact match isn't found on Trakt it can fail. It's not all the time but it can happen.
Most of these problems occur with shows on Apple TV, Disney and Paramount from my testing. Netflix gives bog all info or, not in any way I've been able to find so Netflix just doesn't work at all.
Stuff played through Plex or Infuse via Plex server work perfectly as it gets all the info.
I'd like to speed up detection, make it more accurate on position etc but I've gone about as far as I think I can take this so, if anyone wants to pick up on it and mess with it, you're moe than welcome to do so.
Trakt Scrobbler for Apple TV โ€“ Complete Setup Guide
Automatically scrobble what you watch on Apple TV (Infuse, Plex, etc.) to Trakt. Handles start, progress, pause/resume, and stop, with automatic token refresh and rateโ€‘limit handling.
Prerequisites
  • Home Assistant instance (OS, Core, or Container) with:
    • Apple TV integration configured (entity ID media_player.media_room_apple_tv โ€“ adjust if different).
    • rest_command , input_text , and template sensors enabled.
  • Cloudflare account (free tier works).
  • Trakt account (free).
  • A Trakt OAuth application (create one at trakt.tv/oauth/applications).
1. Set up Trakt API credentials
  1. Log into Trakt.
  2. Go to Settings โ†’ Your Apps โ†’ Create New App .
  • Name: e.g., Home Assistant Scrobbler
  • Redirect URI: urn:ietf:wg:oauth:2.0:oob
  • Keep the Client ID and Client Secret โ€“ you'll need them.
  1. Generate an access token and refresh token using the device auth flow (see below).
Generate Trakt tokens (oneโ€‘time)
Run these commands in a terminal (replace YOUR_CLIENT_ID and YOUR_CLIENT_SECRET ):
# 1. Request device code
curl -X POST https://api.trakt.tv/oauth/device/code \
  -H "Content-Type: application/json" \
  -d '{"client_id": "YOUR_CLIENT_ID"}'
# You'll get a user_code and device_code. Visit the verification_url and enter the user_code.
# 2. Poll for tokens (use the device_code from step 1)
curl -X POST https://api.trakt.tv/oauth/device/token \
  -d '{
    "client_id": "YOUR_CLIENT_ID",
    "client_secret": "YOUR_CLIENT_SECRET",
    "code": "DEVICE_CODE",
    "grant_type": "urn:ietf:params:oauth:grant-type:device_code"
Save the returned access_token and refresh_token .
2. Create Cloudflare Worker and KV namespaces
  1. Log into Cloudflare Dashboard โ†’ Workers & Pages .
  2. Create a new Worker: name it trakt-relay (or your choice).
  3. Create three KV namespaces :
  • TRAKT_SESSIONS โ€“ stores active scrobble sessions.
  • TRAKT_TOKENS โ€“ stores Trakt tokens and client credentials.
  • TRAKT_CACHE (optional) โ€“ caches show search results to reduce API calls.
  1. For each KV, bind it to your Worker:
  • Go to Worker โ†’ Settings โ†’ Bindings โ†’ Add binding .
  • Type: KV Namespace .
  • Variable name: exactly TRAKT_SESSIONS , TRAKT_TOKENS , TRAKT_CACHE .
  • Select the corresponding namespace.
3. Deploy the Worker code
Copy the following code into your Worker editor. Replace the placeholder values with your actual Trakt credentials (inside the cleanShowTitle function you can also add custom title mappings).
// Full worker code โ€“ replace placeholders with your data
// Placeholders: YOUR_TRAKT_CLIENT_ID, YOUR_TRAKT_ACCESS_TOKEN, YOUR_TRAKT_REFRESH_TOKEN,
//               YOUR_TRAKT_CLIENT_SECRET (only needed for token refresh)
let searchCache = new Map();
export default {
  async fetch(request, env) {
    // Admin endpoint to update tokens later (POST JSON with tokens)
    const url = new URL(request.url);
    if (url.pathname === "/admin/tokens" && request.method === "POST") {
      try {
        const body = await request.json();
        const now = Math.floor(Date.now() / 1000);
        const expires_at = now + (body.expires_in || 604800) - 300;
        await env.TRAKT_TOKENS.put("access_token", body.access_token);
        if (body.refresh_token) await env.TRAKT_TOKENS.put("refresh_token", body.refresh_token);
        await env.TRAKT_TOKENS.put("expires_at", expires_at.toString());
        if (body.client_id) await env.TRAKT_TOKENS.put("client_id", body.client_id);
        if (body.client_secret) await env.TRAKT_TOKENS.put("client_secret", body.client_secret);
        return new Response("Tokens updated", { status: 200 });
      } catch (err) {
        return new Response(err.toString(), { status: 500 });
    if (request.method !== "POST") return new Response("POST only", { status: 405 });
    try {
      console.log("๐Ÿ” Mode:", body.mode);
      console.log("๐Ÿ“บ Raw Title:", body.media_title);
      // ---- Token management (auto-refresh) ----
      async function getValidAccessToken() {
        let accessToken = await env.TRAKT_TOKENS.get("access_token");
        const expiresAt = parseInt(await env.TRAKT_TOKENS.get("expires_at") || "0");
        if (now < expiresAt && accessToken) return accessToken;
        console.log("๐Ÿ”„ Access token expired, refreshing...");
        const refreshToken = await env.TRAKT_TOKENS.get("refresh_token");
        const clientId = await env.TRAKT_TOKENS.get("client_id");
        const clientSecret = await env.TRAKT_TOKENS.get("client_secret");
        if (!refreshToken || !clientId || !clientSecret) throw new Error("Missing refresh credentials");
        const resp = await fetch("https://api.trakt.tv/oauth/token", {
          method: "POST",
          headers: { "Content-Type": "application/json" },
          body: JSON.stringify({
            refresh_token: refreshToken,
            client_id: clientId,
            client_secret: clientSecret,
            grant_type: "refresh_token"
        if (!resp.ok) throw new Error("Token refresh failed");
        const tokens = await resp.json();
        const newAccessToken = tokens.access_token;
        const newExpiresAt = Math.floor(Date.now() / 1000) + (tokens.expires_in || 604800) - 300;
        await env.TRAKT_TOKENS.put("access_token", newAccessToken);
        await env.TRAKT_TOKENS.put("expires_at", newExpiresAt.toString());
        if (tokens.refresh_token) await env.TRAKT_TOKENS.put("refresh_token", tokens.refresh_token);
        console.log("โœ… Token refreshed");
        return newAccessToken;
      const accessToken = await getValidAccessToken();
      const HEADERS = {
        "Content-Type": "application/json",
        "trakt-api-version": "2",
        "trakt-api-key": clientId,
        "Authorization": `Bearer ${accessToken}`,
        "User-Agent": "Mozilla/5.0"
      // ---- HTTP helpers with retries ----
      async function traktGet(url, retries = 5) {
        for (let i = 0; i < retries; i++) {
          const r = await fetch(url, { headers: HEADERS });
          if (r.status === 429) {
            const wait = Math.pow(2, i) * 1000 + Math.random() * 1000;
            console.log(`Rate limited, retry ${i+1} after ${Math.round(wait)}ms`);
            await new Promise(resolve => setTimeout(resolve, wait));
            continue;
          if (r.status === 401) {
            console.log("401 received, refreshing token");
            const newToken = await getValidAccessToken();
            HEADERS.Authorization = `Bearer ${newToken}`;
            return traktGet(url, 0);
          if (!r.ok) return null;
          return await r.json();
        return null;
      async function traktPost(url, payload, retries = 5) {
          const r = await fetch(url, { method: "POST", headers: HEADERS, body: JSON.stringify(payload) });
            continue;
            console.log("401 on POST, refreshing token");
            return traktPost(url, payload, 0);
          const text = await r.text();
          console.log("POST response", r.status, text.substring(0, 200));
          return new Response(text, { status: r.status, headers: { "Content-Type": "application/json" } });
        return new Response("Rate limit exceeded", { status: 429 });
      // ---- Title cleaning with manual mappings ----
      function cleanShowTitle(rawTitle) {
        if (!rawTitle) return "";
        // Add any problematic titles here
        const titleMap = {
          "Marshals: A Yellowstone Story": "Marshals",
          "Dutton Ranch": "Dutton Ranch",   // adjust if needed
        if (titleMap[rawTitle]) {
          console.log(`๐Ÿ—บ๏ธ Mapped title: "${rawTitle}" โ†’ "${titleMap[rawTitle]}"`);
          return titleMap[rawTitle];
        // Remove season/episode patterns
        let cleaned = rawTitle.replace(/\s*[โ€“\-โ€“]\s*S\d+\s*[โˆ™โ€ข\-]\s*E\d+\s*[โ€“\-โ€“]\s*.*$/i, "");
        cleaned = cleaned.replace(/\s*S\d+E\d+\s*/i, "");
        cleaned = cleaned.replace(/\s*[โ€“\-โ€“]\s*Season\s*\d+\s*[โ€“\-โ€“]\s*Episode\s*\d+\s*[โ€“\-โ€“]\s*/i, "");
        cleaned = cleaned.replace(/\s*[โ€“\-โ€“]\s*.*$/i, "");
        cleaned = cleaned.trim();
        console.log(`๐Ÿงน Cleaned title: "${rawTitle}" โ†’ "${cleaned}"`);
        return cleaned;
      const app = body.app_name || "";
      if (["YouTube", "Music"].includes(app)) return new Response("ignored");
      let mediaTitle = body.media_title || "";
      let showTitle = cleanShowTitle(mediaTitle);
      let season = body.season ? parseInt(body.season) : null;
      let episode = body.episode ? parseInt(body.episode) : null;
      const combined = `${mediaTitle} ${body.media_artist || ""}`;
      const seasonMatch = combined.match(/S(\d+)/i);
      const episodeMatch = combined.match(/E(\d+)/i);
      if (season === null && seasonMatch) season = parseInt(seasonMatch[1]);
      if (episode === null && episodeMatch) episode = parseInt(episodeMatch[1]);
      // ---- START ----
      if (body.mode === "start") {
        if (!showTitle) return new Response("no show title", { status: 200 });
        let showId = null;
        if (env.TRAKT_CACHE) {
          showId = await env.TRAKT_CACHE.get(showTitle, { type: "json" });
        } else {
          showId = searchCache.get(showTitle);
        if (!showId) {
          const searchUrl = `https://api.trakt.tv/search/show?query=${encodeURIComponent(showTitle)}`;
          const searchResult = await traktGet(searchUrl);
          if (!searchResult || !searchResult[0]) {
            console.log(`โŒ Show not found: ${showTitle}`);
            return new Response(`show not found: ${showTitle}`, { status: 200 });
          showId = searchResult[0].show.ids.trakt;
            await env.TRAKT_CACHE.put(showTitle, JSON.stringify(showId), { expirationTtl: 86400 });
          } else {
            searchCache.set(showTitle, showId);
            setTimeout(() => searchCache.delete(showTitle), 86400000);
        if (season === null || episode === null) {
          const progressUrl = `https://api.trakt.tv/shows/${showId}/progress/watched`;
          const progress = await traktGet(progressUrl);
          if (progress && progress.next_episode) {
            season = progress.next_episode.season;
            episode = progress.next_episode.number;
          } else {
            season = 1; episode = 1;
        const scrobbleData = {
          show: { ids: { trakt: showId } },
          episode: { season, number: episode }
        const sessionId = body.session_id || crypto.randomUUID();
        await env.TRAKT_SESSIONS.put(sessionId, JSON.stringify(scrobbleData), { expirationTtl: 3600 });
        console.log(`๐Ÿ’พ Session stored: ${sessionId}`);
        const postResponse = await traktPost("https://api.trakt.tv/scrobble/start", {
          ...scrobbleData,
          progress: 1
        const responseText = await postResponse.text();
        return new Response(JSON.stringify({ session_id: sessionId, result: responseText }), {
          status: postResponse.status,
      // ---- PROGRESS (pause) ----
      if (body.mode === "progress") {
        const sessionId = body.session_id;
        if (!sessionId) return new Response("missing session_id", { status: 400 });
        const sessionData = await env.TRAKT_SESSIONS.get(sessionId);
        if (!sessionData) return new Response("invalid or expired session", { status: 200 });
        const scrobbleData = JSON.parse(sessionData);
        const progress = parseFloat(body.progress || 0);
        console.log(`โธ๏ธ Pausing at ${progress}%`);
        return await traktPost("https://api.trakt.tv/scrobble/pause", {
          ...scrobbleData,
          progress
      // ---- STOP ----
      if (body.mode === "stop") {
        if (!sessionData) return new Response("nothing active", { status: 200 });
        let progress = parseFloat(body.progress || 95);
        if (progress < 80) progress = 95;
        console.log(`๐Ÿ›‘ Stopping at ${progress}%`);
        const stopResponse = await traktPost("https://api.trakt.tv/scrobble/stop", {
          ...scrobbleData,
          progress
        await env.TRAKT_SESSIONS.delete(sessionId);
        return stopResponse;
      return new Response("invalid mode", { status: 400 });
    } catch (err) {
      console.log("๐Ÿ’ฅ Unhandled error:", err);
Seed the TRAKT_TOKENS KV (oneโ€‘time)
After deploying the worker, run this curl command once (replace placeholders):
curl -X POST "https://trakt-relay.YOUR_SUBDOMAIN.workers.dev/admin/tokens" \
  -d '{
    "access_token": "YOUR_ACCESS_TOKEN",
    "refresh_token": "YOUR_REFRESH_TOKEN",
    "expires_in": 604800,
(You can also use a temporary worker code to seed โ€“ but the /admin/tokens endpoint is simpler.)
4. Home Assistant configuration
4.1 Add input_text helper
Add the following to your configuration.yaml (or create via UI):
input_text:
  trakt_session_id:
    name: Trakt Session ID
    initial: ""
4.2 Add rest_command definitions
rest_command:
  trakt_scrobble_start:
    url: "https://trakt-relay.YOUR_SUBDOMAIN.workers.dev"
    method: "POST"
    headers:
      Content-Type: "application/json"
    payload: |
        "mode": "start",
        "session_id": "{{ session_id }}",
        "app_name": "{{ app_name }}",
        "media_title": "{{ media_title }}",
        "media_artist": "{{ media_artist }}"
  trakt_scrobble_progress:
    method: "POST"
    headers:
    payload: |
        "mode": "progress",
        "progress": {{ progress }}
  trakt_scrobble_stop:
    method: "POST"
    headers:
    payload: |
        "mode": "stop",
4.3 Create the template sensor for watch percentage
template:
  - sensor:
      - name: Apple TV Watch Percent
        unique_id: apple_tv_watch_percent
        unit_of_measurement: "%"
        state: >
          {% set pos = state_attr('media_player.media_room_apple_tv','media_position') | float(0) %}
          {% set dur = state_attr('media_player.media_room_apple_tv','media_duration') | float(1) %}
          {% if dur > 0 %}
            {{ ((pos / dur) * 100) | round(1) }}
          {% else %}
            0
          {% endif %}
4.4 Automations (YAML โ€“ paste into automations.yaml or create via UI)
Start automation (creates scrobble session):
- id: apple_tv_trakt_start_v7
  alias: Apple TV Trakt Start V7
    - platform: state
      entity_id: media_player.media_room_apple_tv
      to: "playing"
      for:
        seconds: 80
  condition:
    - condition: template
      value_template: "{{ state_attr('media_player.media_room_apple_tv', 'media_duration') | float(0) > 900 }}"
      value_template: "{{ states('input_text.trakt_session_id') == '' }}"
  variables:
    my_session_id: "{{ now().timestamp() | int ~ '_' ~ state_attr('media_player.media_room_apple_tv', 'media_title') | slugify }}"
    - service: rest_command.trakt_scrobble_start
        session_id: "{{ my_session_id }}"
        app_name: "{{ state_attr('media_player.media_room_apple_tv', 'app_name') | default('Apple TV') }}"
        media_title: "{{ state_attr('media_player.media_room_apple_tv', 'media_title') }}"
        media_artist: "{{ state_attr('media_player.media_room_apple_tv', 'media_artist') }}"
    - service: input_text.set_value
        entity_id: input_text.trakt_session_id
        value: "{{ my_session_id }}"
  mode: single
Progress automation (every 5 minutes):
- id: apple_tv_trakt_progress_v7
  alias: Apple TV Trakt Progress V7
    - platform: time_pattern
      minutes: "/5"
  condition:
    - condition: state
      state: "playing"
    - condition: numeric_state
      entity_id: sensor.apple_tv_watch_percent
      above: 3
      value_template: "{{ states('input_text.trakt_session_id') != '' }}"
    - service: rest_command.trakt_scrobble_progress
        session_id: "{{ states('input_text.trakt_session_id') }}"
        progress: "{{ states('sensor.apple_tv_watch_percent') | float(0) }}"
  mode: single
Stop automation (when playback ends):
- id: apple_tv_trakt_stop_v7
  alias: Apple TV Trakt Stop V7
    - platform: state
      to: "idle"
    - platform: state
      to: "paused"
    - platform: state
      to: "standby"
    - platform: state
      to: "off"
    - platform: state
      to: "unavailable"
  condition:
    - service: rest_command.trakt_scrobble_stop
        progress: 95
        value: ""
  mode: restart
Resume automation (optional โ€“ fixes position after pause):
- id: apple_tv_trakt_resume_v7
  alias: Apple TV Trakt Resume V7
    - platform: state
      to: "playing"
  condition:
  mode: single
5. Testing
  1. Play a long video (>15 minutes) on your Apple TV using an app that passes metadata (Infuse, Plex, etc.).
  2. After 80 seconds, check input_text.trakt_session_id โ€“ it should be populated.
  3. Check Trakt dashboard โ€“ the episode should appear as โ€œwatching nowโ€.
  4. Pause and resume โ€“ progress should update.
  5. Stop playback โ€“ Trakt should mark it as watched.
Troubleshooting
  • 401 errors โ€“ Your access token expired. The worker will autoโ€‘refresh if the refresh token is valid. If not, reseed with new tokens.
  • Rate limit (429) โ€“ The worker will retry up to 5 times with exponential backoff. If persistent, reduce automation frequency or add delays.
  • โ€œShow not foundโ€ โ€“ Add a manual mapping in cleanShowTitle or find the correct Trakt title.
  • Helper stays empty โ€“ Check the start automation trace; ensure the input_text.set_value action succeeded.
Keeping tokens alive
The worker automatically refreshes the access token using the refresh token stored in TRAKT_TOKENS . No manual intervention is needed as long as the refresh token is valid (usually 90+ days). If you ever need to update tokens, use the /admin/tokens endpoint.
Notes
  • The worker uses two KV namespaces: TRAKT_SESSIONS (required) and TRAKT_TOKENS (required). TRAKT_CACHE is optional but recommended.
  • The Apple TV entity ID in automations assumes media_player.media_room_apple_tv . Adjust if yours is different.
  • For Netflix, Disney+, Paramount+ (apps that donโ€™t expose metadata), this scrobbler will not work. Use Traktโ€™s direct service linking or browser extensions for those.
