Transfer Conbee2 to Conbee 3 with zigpy-cli
Hey everyone,
I have asked this question buried somewhere and figured it would make more sense to start a fresh post as I cannot be the only one with this problem.
I tried the following:
  1. I quit z2mqtt.
  2. I open the TubesZB Zigpy-CLI Tools config
  3. I choose my conbee2 from the list
  4. I enter my HomeAssistantIP to fill the blank
  5. I chose deconz as radio type.
  6. I left the baudrate at 115200
  7. I chose “backup”
  8. I entered the file name “conbee_II”
  9. I unplugged the conbee2 and plugged in the conbee3
  10. I rebootet my mini computer running HA
  11. I ran the TubesZB Zigpy-CLI Tools restore option on my conbee 3 (new file path).
  12. I quit the add on.
  13. I start z2mqtt with the new device path, specific to the conbee 3
  14. z2mqtt is stuck in a loop where all it shows in the logs is 3 lines, each with “starting…” in green writing.
  15. Changing the baudrate during backup to 57600 and to 115200 also resulted in errors.
I will attach my error logs below. Is there anyone who ran into the same issue and managed to find a solution?
When choosing a baudrate of 115200 during backup AND restore:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
 Add-on: TubesZB Zigpy-CLI Tools
 TubesZB Zigpy-CLI Toolsadd-on
 Add-on version: 0.2.2
 You are running the latest version of this add-on.
 System: Home Assistant OS 11.5  (amd64 / generic-x86-64)
 Home Assistant Core: 2024.2.1
 Home Assistant Supervisor: 2024.01.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service zigpy-cli: starting
[17:45:41] INFO: Directoty Exists
[17:45:41] INFO: Running zigpy - restore on /dev/ttyUSB0 to /config/tzb-zigpy-cli-tools/conbee_II
2024-02-12 17:45:42.650 d0f5a498-tzb-zigpy-cli-tools zigpy.application WARNING Unknown device AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xD905)
2024-02-12 17:45:42.681 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 22, Status: TXStatus.SUCCESS
2024-02-12 17:45:42.745 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 23, Status: TXStatus.SUCCESS
2024-02-12 17:45:42.809 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 24, Status: TXStatus.SUCCESS
2024-02-12 17:45:42.873 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 25, Status: TXStatus.SUCCESS
2024-02-12 17:45:42.937 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 26, Status: TXStatus.SUCCESS
2024-02-12 17:45:43.001 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 28, Status: TXStatus.SUCCESS
2024-02-12 17:45:43.065 d0f5a498-tzb-zigpy-cli-tools asyncio ERROR Task exception was never retrieved
future: <Task finished name='discover_unknown_device_from_packet-nwk=0xD905' coro=<ControllerApplication._discover_unknown_device() done, defined at /usr/local/lib/python3.11/site-packages/zigpy/application.py:942> exception=DeliveryError("Failed to enqueue packet: CommandError('<CommandId.aps_data_request: 18>, status: <Status.NO_NETWORK: 6>')")>
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/zigbee/application.py", line 508, in send_packet
    await self._api.aps_data_request(
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 871, in aps_data_request
    rsp = await self.send_command(
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 508, in send_command
    return await self._command(cmd, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 586, in _command
    return await fut
zigpy_deconz.exception.CommandError: <CommandId.aps_data_request: 18>, status: <Status.NO_NETWORK: 6>
  File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 945, in _discover_unknown_device
    return await zigpy.zdo.broadcast(
  File "/usr/local/lib/python3.11/site-packages/zigpy/device.py", line 623, in broadcast
    return await app.broadcast(
  File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 921, in broadcast
    await self.send_packet(
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/zigbee/application.py", line 522, in send_packet
    raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to enqueue packet: CommandError('<CommandId.aps_data_request: 18>, status: <Status.NO_NETWORK: 6>')
2024-02-12 17:45:46.168 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 30, Status: TXStatus.SUCCESS
[17:45:46] INFO: Action Complete
[17:45:46] INFO: zigpy-cli-up script exited with code 0
s6-rc: info: service zigpy-cli successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service zigpy-cli: stopping
s6-rc: info: service zigpy-cli successfully stopped
s6-rc: info: service banner: stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
This is part of the log when I use different baudrates. I couldn’t copy everything as it wasn’t visible in the log anymore:
2024-02-12 18:30:23.792 d0f5a498-tzb-zigpy-cli-tools asyncio ERROR Task exception was never retrieved
future: <Task finished name='discover_unknown_device_from_packet-nwk=0xDD6E' coro=<ControllerApplication._discover_unknown_device() done, defined at /usr/local/lib/python3.11/site-packages/zigpy/application.py:942> exception=DeliveryError("Failed to enqueue packet: CommandError('<CommandId.aps_data_request: 18>, status: <Status.NO_NETWORK: 6>')")>
    return await fut
2024-02-12 18:30:23.808 d0f5a498-tzb-zigpy-cli-tools asyncio ERROR Task exception was never retrieved
    return await fut
2024-02-12 18:30:23.825 d0f5a498-tzb-zigpy-cli-tools asyncio ERROR Task exception was never retrieved
    return await fut
    return await fut
    return await fut
2024-02-12 18:30:26.881 d0f5a498-tzb-zigpy-cli-tools zigpy.application WARNING Unknown device AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x2BB3)
2024-02-12 18:30:26.913 d0f5a498-tzb-zigpy-cli-tools zigpy.application WARNING Unknown device AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xDB98)
[18:30:27] INFO: Action Complete
[18:30:27] INFO: zigpy-cli-up script exited with code 0
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Not familiar, but that appears to be an add-on, right?
Did you ask this question in that git repo or wherever the add-on authors choose to host their primary support? If you did, great, but just thinking the people reading there would have more knowledge of this tool that the general knowledge here.
